Question about Bissell 1867 steamMOP Stick Vacuum
Worked great last time today nothing~~!?
I ALWAYS use distilled water and it has been working just fine today i plugged it in and the light does not come on and seems the heater does not work to create steam/ what gives+
  • bmccort Mar 16, 2009
    Same issue - no red light indicating heating. I have soaked the filter, reseated the handle and yes there is tension on the handle. I hate to go to the expense to replace the whole thing if it is a simple fix but I've done all the things the FAQ suggests.
    Problem Solver:
  • 5 Answers
Possible therno sensor is gone.
Posted on Sep 17, 2009
Black & Decker Steam Buster SV1000. Can't get to steam (or spray). Never used before but have had for several years. Nothing clogged. 50 water/50 vinegar in water reservoir. Vacuum works fine. Pump...
The impellar or your water pump is on its very last broken fin, time for a mew machine or the long hunt to find a replacement impellar
Nov 06, 2014 | Vacuums
Water in shark floor cleaner is not hot
sounds like some kind of bad connection to the heater in it. how about the receptacle to which you plug into the wall,. is it making good contact?
Best regards
Ck
Dec 03, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a euor pro iron 8000 that I lucked up on at a goodwill store. What type of water does the generator use, distilled or tap?
Always use distilled, because tap water will plug the vents with hard water deposits after a period of use. You may need to run a 50/50 vinegar/water solution through first as you don't know what the previous owner was filling it with. Hope this helps!
Feb 01, 2011 | Vacuums
I have the Oreck Sanapathic DMS2000 Handheld Steam Vacuum, but no steam comes out when I push the button. I hear the motor, is there any buttons I am missing or any help on how to make it work, been...
ORECK DMS2000 No Steam
First, tested tank and filter flow together using suction via
plastic tubing. Worked freely Second, removed pump
and disconnected hoses and terminals [watch location,
three terminals on pump, two plugs]. Pump has a slug inside
and I could blow water either way. Sucked white vinegar
both ways until check action returned. Use distilled water
in future!
Apr 26, 2010 | Oreck Sanapathic DMS2000 Handheld Steam...
Lost suction
there is a screen by the brush that may be clogged. Make sure the water tank is on tight
Feb 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
No spray in hands-free mode.
Hi, I had the same problem ... I tried hot water for 30 minutes with no sucess ... then opened the unit and could see nothing real obvious in the solution hoses ... so took the main hose off the valve from the solution tank ... then plugged in the unit over a towel (be careful) ... and selected clean ... the valve opened and a bunch of fluid flushed through - so I knew the valve was ok. I then blew through the remaining hoses and did seem to get some flow .... and reassembeled the unit ... and filled the tank with vinegar solution ... the manual spray immediately cleared with a bunch of dark flakes ... the regular brush spray worked fine.
Sep 11, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Does not pick up water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=529140
Posted by Dreams642 on Apr 20, 2008
I have had my Hoover Floormate for years. It has always worked great but the last few times I used it the amount of water left is tremendous and the container for dirty water was not full at all. I looked at it and the hose going up from the bottom thru the handle is broken how do I fix this.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell 1867 steamMOP Stick Vacuum Logo
170 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
