Question about Itech Blue Pro Bluetooth Stereo Headphones Headset
Sound louder in right Ear!
Him ive got a pair of I-Tech BluePro Stereo Headset, ive connected them and all seems fine, but when i try and play music the sound is louder in the right ear than in the left, is this a fault or someithing ive done unknowingly, any help would be appreciated. Thanks
  • 5 Answers
If its not something simple like a balance control in your player or a bad earbud (try a different set of earbuds w/a 3.5mm jack).
Then try this:
Theres no mention of a balance function in my Itech manual. It could be a loose solder connection on the board. Thats a common thing to happen with and circuit board mounted hardware that goes out of the unit. I.e. to your ears. Ever so slightly move the earbud jack back and forth, up and down and see if you hear static or the volumes change. If so theres 2 things to try....
First try some contact cleaner, spray it on the male jack and plug it in and out of the unit a few times for a simple try at it.
If it still has imbalance then take the cover off, for the jack side of the unit, resolder the little pins of the inside jack to the board (on the backside of the board). Or find someone that can. These units are worth a few bucks to repair IMO.
Hope this Helps
Posted on May 03, 2009
My headset just stopped playin sound???
If the stereo earphone output socket is in tact (not broken), most likely the problem maybe the Earphone-cord is broken.
May 13, 2014 | LG HBS-700 Bluetooth Headset
P11 only plays out one ear.
hi Charzie.
There can be many reasons that a pair of headphones only play audio out of one ear. The most common reason for sound to only come out of one side is the wires near the audio jack have gotten bent back and forth so many times that it has caused a short in the wiring.
read up on how you might be able to fix this.
How To Easily Fix Pair Of Headphones When The Audio Is Only Coming Out Of...
Dec 16, 2017 | Turtle Beach PS3 Ear Force P11 Amplified...
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
My backbeat is paired and working with my sprint evo. but the music will not play at all through the headset? calls are fine but no stereo music . it was working fine before i got a jawbone and paired it...
I wonder if Adroid has some issues with its A2DP stack. You see, I have 3 different stereo headsets paired with my WM6.1 phone, and all of them (one at a time, of course) stream music without any flaws.
Anyway, you could try to delete the Backbeat from the list of paired devices on your phone, and, then, pair them again.
Just my 2 cents...
Hope you are able to sort your problems out soon.
Regards, Carlos
Oct 12, 2010 | Plantronics Backbeat 903 Bluetooth...
Cant hear music through my LG HBS-200 Bluetooth Stereo Headset
I have the same problem with my HBS-250. It was working fine on my iPod Touch. It worked the first couple of weeks on my iPhone 4 then stopped playing music. Phone funtion works. No music or podcasts or streaming from the web
Sep 12, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
May 16, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Sound in left headphone only sometimes works
you can warranty them on there website. they will probably send you a new pair.
May 07, 2009 | Skull Candy SC-INK'D/Blk Consumer...
Left ear of headphones volume low
Out of the box or before using it, you have to charge the headset for about 4hrs or until no light on the headset (red if it's charging). Then try using it again play around with the volume. If you encounter the same thing then you have to replace it at the store.
May 01, 2009 | IOGear (GBE201W7) Wireless Headset
Itech Blue Pro Bluetooth Stereo Headphones Headset Logo
395 people viewed this question
Top Itech Radio Communications Experts
Vernon Taylor
Tom Chichester
Are you an Itech Radio Communication Expert? Answer questions, earn points and help others
