Question about Samsung Audio Players & Recorders
DVD not play dvds and making noises
Samsung surround sound dvd player not read any dvds and making noises
Probably is dirthy laser...
Try to clean it,and,if that doesn't work,you must change it!
Posted on Feb 09, 2009
Acer aspire 5349 wont play dvds only cd
Try installing a new software program to play your DVDs. Also look for updated dvd player drivers from Acer site.
Mar 19, 2014 | Acer Aspire 5920 AS5920 Notebook
Will not play DVDs (no disc message on display),
That usually happens when the laser deteriorates. You can get it replaced but it's not cheap
Feb 06, 2010 | Samsung DVD-HD950 DVD Player
My home theater system plays cds but will not play dvds, what can I do to fix it, makes a scratching noise when i put dvds in it, but plays fine with a cd.
There is something wrong with the DVD drive assembly inside. If you're brave, take it apart and check on what is making the noise. Also, try using a q-tip to clean the laser head if it's accessible.
If that doesn't help, it's time for a new DVD player.
This is why I always recommend people buy a home theater system without a DVD player built in. The DVD player is the weakest link, and stand alone DVD players can be purchased for as little as $25 depending on if you want upconversion or not.
If you cannot get the DVD player working in your surround system, just replace it with a stand alone DVD player, if you can, check to make sure there are audio inputs on the back of the receiver. If there are no audio inputs on the receiver, you will have to get the entire surround system replaced. If so, purchase a separate DVD player and surround system.
Jan 13, 2010 | LG LH-T754 Theater System
When I record to dvd I can't plan on any other DVD player - can play on the toshiba dvr but nothing else?
Have you closed the recording? If the recording is not closed out, you will have trouble playing the DVD in other players.
It could also be that your DVD player you are trying to play on is too old or not designed to use burned DVDs. I also have trouble playing some burned DVD's in older DVD players, it has to do with how the recording is done, and there is nothing you can do about it. For example, I have a Sony 5 disc changer that came with a surround sound set up... nice DVD player, but will NOT handle DVDs burned on stand alone DVD burners or burned from a PC. It reads the DVD, and displays on the front of the player that it is not a DVD, and shows nothing on the TV.
Jan 01, 2010 | Sling Media The Slingbox Pro
Dvd player makes noise, doesn't read discs
mine did the same thing it just kept ticking when i wanted to play a disk, id take to top off with the four tiny little screws and hoover it, mine still makes a bit of noise but works x
Mar 11, 2009 | Panasonic DVD-F86 Multi-disc DVD Player
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
My DVD player will only play background sound not voices
Go to sound menu of dvd player and select Stereo sound and if surround is enabled, disable it.
You can get help from user manual of dvd player.
Nov 09, 2008 | Televison & Video
Emerson ewr10d4
emerson dont have cotex u need buy samsung emerosn worse brand to play new dvds ok just wont read them right its dvd it self players cotex not up to par to read newer dvds samsung makes best 1080 p upconverting one 79 at circiut city i seeen thzx inck
Oct 06, 2008 | Emerson EWR10D4 DVD Recorder
LX3000D DVD Digital Surround System
the dvd player has a strip that comes from the lens to the board have that checked out by a yech probably it is broken or needs to be cleaned.
Mar 07, 2007 | Philips LX3000D System
135 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
