Question about Canon imageCLASS 4000 ED Laser Printer
Error page printing after every job on Canon ImageClass 4000
I have someone using a Canon ImageClass 4000 printer in an all Mac environment. After each print job, an extra sheet is printed with the following "descriptive" message:
"ERROR: undefined
OFFENDING COMMAND:
STACK:"
The printer is set up on all the computers via AppleTalk and it happens when you print from any of the machines. I haven't tried it from Parallels yet but I may do that when I'm there tomorrow. I also might try setting it up with the IP rather than AppleTalk.
It has an Ethernet port and when I got there last time it was assigned to some 148.x.x.x number which is not the subnet so I assigned it to 192.168.x.x, which I suspect is when the issue started happening, but when I switched it back it didn't change anything.
I've also tried several cold resets. Is there a hot/hard reset? What can I do to fix this do you think?
  • 1,602 Answers
STACKING IS A MEMMORY ISSUE OR THE POCESSOR CANNOT DO ANYMORE WORK UNTIL IT GET SERVICED.
OR
APPLE TALK SHOULD BE FORWARD AND EASY TO SETUP AND ON THE OTHERHAND YOU MAY NEED TO HAVE THE NETWORK SOFTWARE FOR APPLE CONFIGURATION, IT HAS BEEN ALWHILE SENCE I WORKED ON THE APPLE TALK, I CANNOT THINK OF THE SOFTWARE YOU NEED BUT THE OTHER OPTION IS NETWORKING IT IS GOOD OPTION IF AGAIN YOU HAVE THE PROPER SOFTWARE AND DRIVER TO HOOK IT UP TO A NETWORK THREW IBM/MAC COMPATABLE SYSTEM INTERCHAGEABLE SOFTWARE.
ALOT OF THIS HAS TO DO WITH THE NETWORKING AND SHARING PROGRAM, OTHER OPTIONS BEFORE YOU GO THREW ALL THE WORK IS CHECK OUT OTHER IDEAS, HETWORK ASSIST, CONTROL PANAL AGAIN, WIFI IS THE MAC WIFI CAPABILE, IS THE PRINT SETUP TO DO WIFI, THERE IS AN ADAPTER IS ABOUT 30.OO DOLLARS THAT YOU PUT THIS USB ADAPTER IN THE PRINTER CABLE CONNECTOR AND THE OTHER END IN THE SERVER OR COMPUTER AND THAN YOU ARE WIFI AND EVERYONE CAN SHARE AS LONG AS YOU SAY ITS OKAY TO SHARE IN THE NETWORK AND SHARING FOLDER
ROD
Posted on Feb 09, 2009
My cannon D680 prints a blank page after every print or copy job. the pages print fine but at the end it always feeds 1 blank page. what can it be?
See if there is an option in your settings to print a "job owner" page after each job. That's not what it's actually called but I had a similar issue with a Canon printer and found that you can have the printer automatically print a page after the job that identifies who sent the job to the printer. It's the last page so it lands on top of a finished job and separates it from other jobs sent to the printer before you have a chance to get yours. If you don't have network identifications associated with users it may just print a blank page as a separator.
Jan 14, 2015 | Canon imageCLASS D680 Laser Printer
MF 4150 can only print 1 page
Are your print commands ok for printing ALL pages? check
Do you not have the printer manual for troubleshooting?
Jul 14, 2013 | Canon imageCLASS MF4150 All-In-One Laser...
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
How do you make a canon d761 work with mac osx?
I am really sorry to tell you that your device is not compatible with MAC environment .
Its only compatible with windows.
Please let me know if you have any further questions or concerns.
Thanks.
May 03, 2010 | Canon imageCLASS D761 Copier
Printer not printing
Go to the printer properties and make sure there is not a previous print job. Cancel all print jobs. Then send a test print to the printer.
Mar 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
MF8180C Check paper size error
for god's sake don't ring canon customer service as they are useless and just keep directing me to their **** driver which is causing the problem. i could not convince them that my "printer properties" "paper available" was locked on "letter" and won't allow me to change it. even when i go to the "printer preferences" page and set everything to a4 and press "apply" it still is locked on "letter" in the "printer properties" page. Iv'e probably wasted about 20 hours on this and my office has nearly ground to a halt. If i knew it was going to be this much bother i could have just bought another brand printer.
Nov 27, 2006 | Canon imageCLASS MF8170C All-In-One Laser...
Canon imageCLASS 4000 ED Laser Printer Logo
110 people viewed this question
old marine
old marine
