Question about Car Audio & Video
Aiwa cdc-r30mp demo display
Cannot get the demo display off and the clock to show the time permantely without getting the demo back on stereo holds the memory when turned off
  • 1 more comment
  • Neil Cook Feb 09, 2009
    have lost user manuel due to field mice last winter & cannot remember the procedure
  • fragglesde Apr 01, 2009
    Aiwa CDC-R30MP
    Cannot connect the radio to my car because the wired connector
    was lost (in space ;-))
    any hints (pinout,manual,servicemanual) to get this thing working?
    special thank´s for an answer
    from Marc in Germany
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Demo Off procedure is written in related user manual.
    If problem still exists, let me know.
  • 10,594 Answers
OK,
Please make sure Yellow wire (back up supply) is connected with Ever-12 Volt line (should not switch off with ignition) and press DSPL button to et display on clock.
Posted on Feb 09, 2009
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Hi - I just moved and when I hooked up my 2003 Panasonic SC-AK100, it stays in 'demo' mode and won't shut off completely...after showing "goodbye" and apparently shutting off, it comes back on...
http://www.retrevo.com/support/Panasonic-SC-AK100-manual/id/356ag917/t/2/
Page 12:
A demonstration of the display is shown if you have not set the clock.
You can reduce the power consumed in standby mode by turning it
off.
During standby mode
Hold down ['square icon'/-DEMO] until "NO DEMO" is displayed.
Every time you hold down the button:
NO DEMO (off)↔DEMO ON (on)
To show a demonstration of the display
Hold down ['square icon'/-DEMO] until "DEMO ON" is displayed.
Jan 16, 2011 | Panasonic SC-AK100 CD Shelf System
How do I set the time on my kd s15
you have to hold down the sel button until you see DEMO pop up on the screen then it will show demo on. then turn the volume knob up or clockwise and it will say DEMO OFF. then click the right arrow and it will go to clock display. Turn the volume knob until it says on. then hit the right arrow and it will say abb. clock hour then turn the knob until it is the right hour. then click the right arrow and it will say abb. clock minutes and turn the knob until it is right.
Good Luck
Dec 11, 2010 | Car Audio & Video
How to set time on jvc kd-r210
Setting the clock
  • Press and hold SEL (select) for more than 2 seconds. "DEMO", "CLOCK H", "CLOCK M", "DIMMER", or "AMP GAIN" appears on the display.
  • Set the hour.
  • 1. Select "CLOCK H" (hour) if not shown on the display.
  • Set the minute.
  • 1. Select "CLOCK M" (minute).
  • 2. Adjust the minute. Using the Control Knob
  • Finish the setting. To check the current clock time or change the display mode.
  • Press DISP (display) repeatedly. Each time you press the button, the display changes as follows:
  • • During tuner operation:
  • • During CD operation:
  • • During power off:
  • The power turns on and the clock time is shown for 5 seconds, then the power turns off.
Nov 11, 2010 | JVC AM FM CD DET FACE CAR STEREO
I CANNOT SWITCH OFF THE EQUIPMENT ,AS SOON AS I GET TO SWITCH OFF THE HI FI IN A FEW SECONDS THE EQUIPMENT SWITCH ON AGAIN AND I CAN SEE THE WORD DEMO ON THE SCREEN
RTFM: Page 13:
"A demonstration of the display is shown if you have not set the
clock. You can reduce the power consumed in standby mode by turning the demonstration off.
While the unit is on:
Press and hold [–DEMO] until “NO DEMO” is
displayed.
Each time you press and hold the button:
NO DEMO (off) DEMO (on)
This is a 24-hour clock.
The example shows how to set the clock for 16:25 (4:25 p.m.).
1 Press [0/I] to turn the unit on.
Press [CLOCK/TIMER] to display “CLOCK”.
Each time you press the button:
CLOCK>>PLAY>>REC>>Original display
Within 5 seconds
Press [SET].
Press [TUNING (Up or Down)] to set the time.
The time display can be changed in one minute units by tapping
the buttons, and quickly by holding down the buttons.
Press [SET].
The time is set and the original display is restored."
Or under Troubleshooting Page 38:
"The display starts up even after the unit is turned off.
The demonstration feature (–DEMO) is on. Turn it off if it is not required."
If you need the manual go to
http://audio.manualsonline.com
register and get it for free.
Mar 25, 2010 | Technics SC-EH780 CD Shelf System
How do I set the time on a JVC KD-S13 car stereo?
Press and hold 'SEL' button. DEMO is displayed. Use the up or down to select an item. Turn volume knob to set/adjust. The clock is next after demo. set hour then minute press SEL to finish. Reference page 3 in this link to JVC for your KD-S13 CD Receiver Instructions.
http://books.jvc.com/Download/975469902/GET0400-001A.pdf
Dec 27, 2009 | JVC Car Audio & Video
How to set the clock on a Sanyo DC-DA1100 stereo?
This is taken from the user manual.
If switched on, press the ON button to turn the unit off.
Press the CLOCK/TIMER button for at least 2 seconds so that the clock icon blinks on the display.
Press the MEMORY button. The hours display blinks.
Turn the VOULUME control to set the hours.
Press the MEMORY button. The minutes display blinks.
Turn the VOULUME control to set the minutes.
Press the MEMORY button. The clock starts.
NOTE: the time can be set accurately by pressing the MEMORY button when a time signal is heard.
Changing the clock to 12 hour display.
When the clock is display, press the MEMORY button and hold it, then press TUN UP buttom (this will change from 24hr format to AM/PM format)
Nov 02, 2009 | Sanyo DC-DA1000 CD Shelf System
Can't get it out of demo mode; radio/cd changer won't come on. reads only welcome to sony and shows clock.
try holding down the mode or power button... another menu should pop up... also refer to manual
May 28, 2009 | Car Audio & Video
How do i set the time and remove the demo setting
Hello again johnworley6,
To set the time and/or cancel the demo mode, you need to enter "PSM" mode. Do this by pressing and holding the "sel" button for 4 seconds. Use the left/right rocker switch to select the item. Turn the "volume" knob up/down to change the item. Press "sel" again the exit PSM mode.
So to turn demo mode off: 1) Press and hold "sel". 2) Press right until "demo" is displayed. 3) Turn volume knob until "demo off" is displayed. 4) press "sel" again to exit PSM.
To set the time: 1) Press and hold "sel". 2) Press right until "CLOCK H" is displayed. 3) Turn volume knob until correct hour is set. 4) Press right until "CLOCK M" is displayed. 5) Turn volume knob until correct minutes are set. 6) Press "sel" to exit PSM.
Hope this helps. If it does, please rate as "FixYa".
Apr 25, 2009 | Car Audio & Video
Demo problem
Here is how to shut off the demo:
1) Press and hold the SEL button for several second until DEMO appears on the display. Release your finger from the SEL button.
2) Using the Volume control knob, turn left or right to turn on/off DEMO.
3) Press and release the SEL button to accept.
Setting the clock:
1) Press and hold the SEL button for several seconds until the DEMO shows on the display.
2) Use the right search arrow in the 4-way button just above the SEL to get to the clock hour. Do not use the up or down key.
3) Turn the volume control knob to select the hour.
4) press the right arrow once more to get to the clock minute.
5) Turn the volume control knob to select the minute.
6) When finish, press and release the SEL to accept.
Good luck
Sep 02, 2007 | JVC KD-G230 CD Player
Car Audio & Video Logo
1,065 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
