Question about Toshiba 32AF41 32" TV
My rca tv not working
My tv is not working i change the lamp , but now i can hear, and see nothing
    Sergeant:
  • 250 Answers
The lamp which you rteplaced is not seated properly.and also it can be the problem of colour wheel or the ballast.to check out all three just check out this links 1 by 1 for colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
for lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
for ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Posted on Feb 09, 2009
Where do i go to change the lamp bulb on the model kdfe42a10
I'm glad to assist you with providing the instructions to change the lamp of the TV. Please click hear to order for the compatible lamp for the TV.
In order to view the instructions to change the lamp, please refer page # 86 of the Instruction Manual of the TV.
Please click hear to download the Instructions Manual if you don't have a hard copy in hand.
Thanks for understanding. Please let me know if you require any clarifications.
Jun 15, 2011 | Televison & Video
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
I have a mitsubishi wd-60735 tv when i turn the tv on nothing comes on only hear the volume and screen just pitch black?
Did you recently replace the lamp? If you did then it might be the new lamp. I mistakenly bought an aftermarket lamp to replace mine and it would not work consistently. Apparently if it is not an Mitsubishi original lamp it has issues, because after I replaced it with a Mitsubishi lamp it worked perfectly fine.
Aug 14, 2010 | Mitsubishi WD-60735 Projection Television
Install new lamp, nothing comes on ,change back to old lamp still nothing
Hi,If the lamp didn't do the work it could be that the problem is with something else.If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Do you hear buzzing or high pitch sounds? If you do it could be a problem with the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Make sure the door cover is properly shut other wise it wont lamp light up.
Apr 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung SP50L6HX, I replaced the Lamp but still nothing.
Hi, Samsung haves a known issue with the ballast, once you make a replacement of the lamp, sometimes its harder to ignite a new lamp that has 100% of gas inside than igniting a old lamp that has maybe 60% or 50% of gas inside. Just in order to ignite the lamp, the ballast needs to send some High Pulses of Voltage, as high as 15 kV (that is the constant clicking sound that you are hearing). In order to resolve this you need to change the Ballast Board. I tried to look for your ballast with your TV Model # at samsungparts.com , but nothing showed up. You will need to find out which ballast part # you have in order to find it online. To locate the ballast part # please check the end of this video, you only need to take the lower back cover of TV off. http://www.youtube.com/watch?v=0jr_9A5Xd2Q
Here is a link of a ballast I found http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1138231.htm?Click=49915
Dec 24, 2009 | Samsung SP50L6HX 50" DLP HDTV
Sony kds-60a2020 lamp problem
I would change the whole LAMP ASSEMBLY because if you touch the lamp while changing it out of the housing the oils on your hands will cause premature failure.Most of the time the lamp assembly's come with replacement instructions but yours is not too bad it is located on the left hand side if looking from behind set.
Sep 10, 2009 | Sony KDS-60A2020 60" HDTV
TV won't turn on
you need to replace the lamp in your tv, it is easy and you can do it. Look on the sides of the set for a door labled lamp, with the set unplugged open it up and remove the lamp, if the bulb is out it will have lots of glass in the lens
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV not turning on
This is the lamp error code. The lamp part# for your unit is
TS-CL110U. Hope this Helps.
Mar 21, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Toshiba 32AF41 32" TV Logo
123 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
