Question about Philips Televison & Video
Phillips 55'' rear projection tv model #55pp970104
Apparently there are two separate connections. One of them went out causing the picture to become all pink. The repairman hooked it to another connection and then on the ''focus'' menu we put it on #4 HDTV and the picture was normal. We left it on that setting and the set was working fine. I recently gave the set to my son and now the picture is pink again. I can get the ''focus'' menu to go on #4 HDTV but then the cable picture goes out. He has a cable box. So the set works fine as long as I leave the setting on antenna A and the cable channels come in but are pink and unless it stays on that antenna, the tv picture doesn't come in on #4 HDTV. It did before.
  • frankcelebre Feb 15, 2009
    Phillips 55" rear projection tv model #55pp970104. When you select the picture source button a screen comes up with various selections. The set has an AUX 4 HD Y PbPa connection. It was originally set on Antenna A but that commection burned out causing the entire picture to be pink. The channels all came in but all pink in color and you could not use your cd player either as it was pink. A Phillips technician told us when he came out to fix the set he would set it on the AUX 4 HD on the menue because that set had two separate connections and when the Aux 4 HD was connected it corrected the picture back to natural. I gave the set to my son and didn't pay attention to where the cables were hooked up so now just hooking them up by color naturally and putting it on Aux 4 HD still left the picture pink. I must be missing the correction cable connection on the back of the set.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding all that you need is which jacks of the cable box has to be connected to which jacks of the Philips TV. Limiting conditions are:
  • can not use the standard Antenna A connections since the Philips would display a pink video;
  • you do not recall how and where they were connected to effect HDTV 4 setting in the Source Selection.
Your additional information of 'AUX 4 HD Y PbPa connection' is significant. It tells us that HDTV 4 is used for component type of inputs; therefore the cable box has to have similarly component level, meaning at the rear of the cable box, there should be a similar Y, Pb, Pr.
If none exists (Y, Pb, Pr at the rear of the cable box), determine if it has a composite (yellow jack) and if a similar one exists in the Philips TV.
Alternately if at all possible, post back with photos of the rear/connectors/ jacks of both the Philips and the cable box or list them in the comment box.
Good luck and thank you for using FixYa.
Posted on Feb 15, 2009
  • 744 Answers
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc...
thank u!!!
  • Philips Master
  • 19,396 Answers
That is a convergence problem, it may be because of a faulty defective IC.
Posted on Feb 09, 2009
  • Ginko
    Ginko Feb 09, 2009
    That looks like a convergence problem because of a defective convergence IC (STK) on convergence board.
    The technician must test the pico fuse at the base of the convergence ICs , then replace the ICs.
    Here is the complete procedure: Fixing Convergence problems in RPTV's
    If this is a CRT model , check that one of the three crts is not going off because of a bad ballast board.
  • Ginko
    Ginko Feb 15, 2009
    Check all the cables at teh back, if this is not a fault it is a cable problem.
Cant change channel and/or input mode, picture is horizontally scrambled?? Philips 55PP970104
Possibly, your small signal board needs replaced! It is usually located on the left side on the backside of the tv. It is inserted into the convergence board. This is a good place to start. Hope this gives you an idea to speak with a TV tech!
Jan 17, 2010 | Philips 55PP9701 55" Rear Projection...
OK friends. You've helped me with a TV once before. Now I need your help again. I have a 55 inch Phillips rear projection. Model# 55PP970104 Serial# 58610822 Chassis Model# DPTV210 born on 6-13-01 I bought...
sounds like loose solder or crt board...hard to say.
I have the exact set in the shop - same problem - but I have not gotten around to playing with it...
Mine does the same...warms up - works...
Email www.TvRepairKits.com - they may be able to help.
Ed
Jun 10, 2009 | Philips 55PP9701 55" Rear Projection...
55" philips rear projection Tv model 55pp970104 with no red or intermitting red .
sounds like a defective red CRT drive PCB. You will need the one for the DPTV 300 series Phillips. You should be able to get a replacement at the following link.
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Televison & Video
My Phillips Rear Projection TV (Model Number 55PP970104) has a very weak picture. I took the back casing off and dusted off the projectors with a lens cloth for my digital camera. I also dusted off the...
Look into the lens of the blue CRT while the set is playing see if a picture is present as in the red and green if not youre likely needing a blue CRT or the coolant changed.
Jun 28, 2008 | Televison & Video
Help
Change the CRT coolant in the green and blue tubes thats a comon problem with that model. You will be amazed at the results that changing the coolant will have on color, it will make it look like new again.
Jun 13, 2008 | Philips 55P8341 55" Rear Projection...
55 inch phillps projection tv model #55p8341
you have to have your ant/cable connected to but tunners on the back you should see a ant1 and a ant2 then select pip from your remote
Jan 20, 2008 | Philips 50P8341 50" Rear Projection...
No picture
voltage tripler...and deflection bd........
Jan 13, 2008 | Philips 55PW9363 55" Rear Projection...
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
503 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
