FixYa.com
Tags:
E-Mu 1212M Sound Card
Best Soundcard for RMAA Measurements?
By Peter1 - usenet poster
Hi, all. I'm new to the group. I have designed a D/A converter, and
I've been thinking about how to go about doing measurements on the
analog (single-ended) RCA output. I will probably use the RMAA
software (you know, because it's free). So, I'm trying to figure out
what soundcard (preferably USB, but internal PCI, if that's better)
would be good for doing these types of measurements. Clearly, I don't
want the soundcard A/D to be the limiting factor, in terms of S/N,
DNR, THD, etc. I figure you guys must have some suggestions for me.
I've looked at E-MU 1212M (seems ideal, except has balanced inputs)
and 0404 USB, M-Audio 2496 and USB Audiophile, Onkyo PCI-SE200, and
some others. It's hard to know what it the best value/performance.
Thanks, in advance, for comments.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 11, 2008
Not Rated (0)
unknownsound
Rank:Apprentice Apprentice
Rating: 92%, 4 votes
Using the 1212m as a comparitor/test is a good choice as it has the highest S/N Ratio (120db) on the market. I was attracted to the card(s) because they have the same converter chips as the DigiDesign HD Pro systems (WOW) >and less than the $10,000 to over $150,00 price tag of the DD HD Pro Stuff. But I would not modify the 1212m> use it as a test/monitor instrument. I would use a top notch DVD Player and swap out the chips> if you want to test a UNBALANCED source. And I'd find a Pro (ie: BALANCED) CD, DVD or standalone converter to swap out the chips for a balanced source.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 01, 2007
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
There are plenty of "low" and "medium" end A/D converters around. Why
design one more? I take it this is an experiment or learning
experience and not a real audio/musical product.
Solution #3
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rating: 0%, 0 votes
I don't remember saying "high-end".
Solution #4
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
Although you probably can't test every aspect of your DAC with a
Pro-sumer sound card, there is plenty you can do, simply by making an
LC notch filter and attenuating the main signal. Drop it by 20dB, and
virtually any 24 bit sound card will yield information about spurious
outputs right down to the noise. That should be a relatively trivial
task.
Then hire the expensive stuff for no more than a day or so to do the
trickiest measurements.
d
Pearce Consulting
Solution #5
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
If it's a high end D/A why are you using an single ended RCA output ?
Graham
Solution #6
Not Rated (0)
Horner
Horner - usenet poster
Rating: 0%, 0 votes
Thanks, I think you're right. I may not be able to afford it, but
either way, the "prosumer" soundcards probably aren't good enough for
what I want to do.
Solution #7
Not Rated (0)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
You need something that is an order of magnitude more accurate than
the DAC you are measuring. I assume your DAC is very clean... if it
isn't, there probably isn't any sense in building it in a world of
cheap soundcards. So this means you need a test rig with converters
that are even more clean.
I think you need to bite the bullet and borrow an Audio Precision testset.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Can you Help with these Sound Cards problems?
Sound Cards
tarjeta de sonido
No conozco el modelo ni marca... Answer This...
Sound Cards
sound and the 3D graphics
My Laptop has a problem with... Answer This...
Sound Cards
Please help me
No sound card was found. If... Answer This...
Sound Cards
Sound recording
on my dv6000 I have the choice... Answer This...
Noise on the Input
The output from the card has... Answer This...
Repair Service
Find Sound Card Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
