Question about Stainless Ovens
I have no heat
All the knobs and timers are set correctluy but there is no heat. Any ideas?
  • 979 Answers
You may have a blown fuse or a tripped breaker. The fuses are located within the oven inside the panel.Next, turn off the breakers then back on. Next check the wiring within the control panel. it may be a simple as a wire or 2 has burned off. More than likely you will find this problem in one of the 3 areas I mentioned. Let me know how you do or if you have any other questions.
Posted on Feb 11, 2009
How to set the timer!?
No idea about your oven in particular, but the set button will get you started. From there use the + and - buttons until you have the correct time set. The ok button should finish it for you. If that don't work try the user manual.
Jan 16, 2015 | Ovens
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Mar 02, 2011 | Ovens
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
Oven not heating
If it has a digital timer, make sure it is set to auto and not manual, as oven will not heat if it is on auto.
If it is a anolgue timer ,then it should be showing a hand symbol,if it is not, then turn knob or dial until it does.
If these settings are o/k, then could be a faulty element.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Ovens
Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Nov 28, 2008 | Neff B1432 Single circotherm plus Electric...
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Neff B1442 Oven -- Defective timer and clock
Hi.
Is it flashing AUTO, If it is and you can'y reset it back to manual, then you have faulty timer.
Hope this helps
Nov 25, 2008 | Neff U1661 Double circotherm super...
XL 44 Gas Range Oven temperature problem
hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Nov 06, 2008 | Ovens
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Jenn Air 88370
You need a new knob part y715403 . Turn knob clockwise first clik should be bake position
Jan 08, 2008 | Ovens
Ovens Logo
42 people viewed this question
Top Stainless Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Stainless Oven Expert? Answer questions, earn points and help others
