Question about Kenmore Elite 45986 Front Load Washer
Kenmore washer 110.45981 400
The light "control locked" is on how I can fixed
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Have you tried pushing and holding the DRAIN/SPIN button for three seconds? This button is normally used to lock the control panel as a child safety feature. The instructions should be printed on the front panel near the button.
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
  • Diane Jewett Dec 02, 2012
    This did not work, neither holding down the dry/spin or end of cycle buttons
    President:
  • 1,294 Answers
Hold down 'end of cycle' for 3 seconds. Power shd be on.
Posted on Mar 26, 2009
    This didn't work
jsrock516
  • 5911 Answers
SOURCE: Door Lock error code
Double check your other posting. I have already provided you with a solution, complete with part number and instructions.
Posted on Nov 01, 2007
  • 1294 Answers
SOURCE: Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Posted on Jan 02, 2008
  • 91 Answers
SOURCE: Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Posted on Jan 02, 2009
Maytag317
  • 1136 Answers
SOURCE: kenmore 70 series, 110 washer leaks water when
Hi, You will need to change the inlet mixer valve. It is sticking open just enough to allow water to drip through it. This should be chandes asap so that it doesn't get bad enough to over flow the washer.
Here are directions on how to remove the cabinet so you can get to the inlet valve.
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore 70 series washer 110 22702100
3.2 cu Ft
Posted on Sep 15, 2010
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Always look for an 800 number for the manufacturer try that first.
Nov 28, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
HE3 front load washer has "control Blocked" light is on. No button works on control panel.
You have locked the control via the "Child Lock." Look for the button with a small padlock icon on it, press and hold for about 4 seconds to unlock. That should fix ya!
Sep 11, 2010 | Kenmore HE2 Plus Front Load Washer
Controls locked light
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
Check below link for detailed explanations
http://www.fixya.com/support/r3608801-control_panel_lock
Courtesy JSROCK
Mar 31, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 front load washer the control lock is on and I don't
Look close at the panel.... it will tell you what button to hold in for 3-5 seconds
Good Luck!
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Adjacent to the "Control Locked" light is the DRAIN/SPIN button. Push it in and hold for 3 seconds. This should unlock the control panel. If it doesn't, let me know.
This is a designed feature of the washer to lock the controls to prevent small children from accidentally turning the washer on or manipulating the controls in any way. The control can be locked by holding the DRAIN/SPIN button in for seconds, and released the same way. If someone leans against the button this can also occur. Hopefully this will be an easy fix for you. I hope this helps.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
WHirlpool duet washer is stuck on "controls locked"
we ended up holding the drain/spin button for a period of 15 or so seconds and the issue resolved.
Mar 30, 2008 | Kenmore 42822 Front Load Washer
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
I had the same problem. If you will hold the "Drain & Spin button" in for approximately 4 to 5 seconds it unlocks the " Control Locked" issue.
Dec 18, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
483 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
