Question about Logitech Z-10 Computer Speakers
Logitech Z-10 speakers stopped working, no power
Wondering if it could be a fuse? If so is there a fuse in each speaker and where can I purchase them???
  • 1 more comment
  • Anonymous Mar 08, 2009
    They randomly stopped working and now I can't turn them on!
    Is there a quick and preferably free way of fixing them from home?
  • crystagrophy Apr 17, 2009
    they were working and then WHAM they just stopped. I tried unplugging them and using a different USB cable, but to no avail... they do not work any longer... and they are expensive... makes me really really angry.
  • Anonymous Apr 21, 2009
    I have the same problem. No power perhaps because the touch sensitive pad is defective. Can the pad be replaced, or can the problem be easily diagnosed?
I experienced the same problem, where the symptom was initially that the volume setting was misbehaving in that you would press the to increase the volume and it would go to the maximum, and likewise press the down button and it would go to the minimum volume.  Then the screen appeared incomplete and finally it did not power on when pressing the power button.  The solution I found was to unplug the power (overnight in my case) to allow any power to drain from the unit and transformers, and then plug it back in.  It powered on afterward.
Posted on Apr 28, 2009
My symptoms were that the speakers stopped working all of a sudden. Display showed power but gave no access to volume adjustment and did not play sounds.
I read a vague comment by another poster and it worked!
They said to unplug it from the power plug and leave it overnight before replugging it in...... at first I dismissed this, and tried everything else to no resolution. I was ready to return the speakers but decided to unplug it and see... Bingo********! in the morning
Posted on Aug 01, 2009
    Problem Solver:
  • 7 Answers
As those speakers are quite expensive i would just recommend don't mess around with the fuse or anything just ring up logitech and if you have got warranty then it should be covered if there is a cost and it is reasonable then just get logitech to fix it , it is the safest way, if you mess something up logitech might even refuse to fix it whether you pay or not.
Posted on Feb 11, 2009
My solution was contacting logitech and having them replace the speakers.
Posted on Apr 29, 2009
Logitech z5500 speakers no power
certainly sounds like a fuse problem. First check that the fuses you have used work in another appliance. You should not have to use a fuse from the logitech company but it will be rated for your speakers so would probably be best. If the fuse checks out (both plug and amp) then check the wall socket and the power cable.
Mar 29, 2010 | Logitech Z-5500 5.1 Digital Speaker System...
My logitech speakers are not working
Have you got any more information on what is/isn't happening? No power, power lights on but no sound etc?
Back when I worked for a company that sold Logitech speakers the most common faulty with the X series was a small fuse that would blow. Usually the speakers would appear to receive no power at all if this was the case.
It's a $10 part if your speakers are out of warranty. Sometimes Logitech may even send this part out for free. Check your warranty though, in some countries there is up to 2 years on these speakers.
If it's a different problem, a little more information on the problem may help the FixYa community to give you some better advice.
Nov 20, 2009 | Logitech X-530 Computer Speakers
I tried to extend the length of my front right speaker (power/vol) by purchasing a male to female VGA extension cord. When I connected bothe cables together and then to the sub everything stopped working...
I doubt the extension cord has something to do with that...Usually if the wires are short it would effect the main unit. Check the wires first,not only of the front right speaker but the others also...if they are short. If there's a fuse in the main unit you might find yourself lucky...otherwise you will have to get it checked by a mechanic.
Aug 06, 2009 | Logitech X-530 Computer Speakers
I have Logitech X-230 speakers. The left speaker
CHECK THE POWER SUPPLY TO THE SPEAKERS
REPLACE ITEM IF POWER TRANSMISSION IN NIL
Jul 18, 2009 | Logitech X-230 Computer Speakers
Logitech x230 speaker system right hand speaker stopped working
speakers do unfortutionly go bad better just to buy another speaker just watch the ohms should not be more than 8 ohm speaker. please make sure you can return if you buy incorrect.
Nov 18, 2008 | Logitech X-530 Computer Speakers
No power in Z-5500 logitech speakers
The logitech z 5500 digital is very sensitive to power peaks. One of the most know problems is that the fuse breaks because of these peaks. I´ll show you how to replace the system´s fuse.
First of all, you just need to write down the specification of the system´s fuse. The system´s fuse specifications are printed in the back side of your subwoofer, right next to the subwoofer´s on/off switch. In an european system it says: "T2AH250V (Time Delayed)". If you use another power voltage (120v), it may say something different. Anyway, write it down on a piece of paper and go to an electricity store and ask for a similar fuse (It is very cheap. Not more than 1$)
-The best way to get a similar fuse would be by bringing the broken fuse with yourself to the store-
In the back of your subwoofer, using an screw-driver, un-screw the fuse´s cover and remove the broken fuse. Replace it with the new fuse, attatch it to the cover and screw it back again.
If you turn on your system now, it will probably work fine.
Oct 20, 2008 | Logitech Z-5500 Computer Speakers
SPEAKER FRONT RIGHT NOT WORKING?
ive got the same problem but with my z5500
wonder what it is?
Mar 16, 2008 | Logitech Z-5300 Computer Speakers
Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Jan 12, 2008 | Logitech Z-2300 Computer Speakers
Logitech Z-680
You need a 2 Amp Slow Blow fuse. 250V. Available from eBay
Aug 01, 2007 | Logitech Z-680 Speakers and DVD218 System
Logitech Z-10 Computer Speakers Logo
4,165 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
