Question about Husqvarna Viking 1
Viking 940 Sewing Machine will not run.
My wife took it to a Viking repairman because it would not run. It did before when she would wiggle the cord where it plugs into the machine.
He said it now blows fuses and it might need a new transformer?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
The transformer has broken solder connections between the pins for the plug and the transformer board. Brave? 4 phillips screw. Black box on bottom. remove ribllon cable. Transformer out. 2 screws black cover on transformer off. Theres the board with broken solder joints to the plug pins. The large plug they used on that model broke the solder joint easily. it shoudlnt be blowing fuses though unless he tried to fix it and put in wrong one.
Posted on Mar 19, 2009
Biking Husqvarna 940 + bobbin case falls out
Go to www.youtube.com, look for how to install a vertical bobbin case. You don't have to find a Viking 940 because a vertical bobbin installs the same in most machines. They have good tips and it is free.
Jan 23, 2018 | Husqvarna Sewing Machines
I replaced the foot control on my Husqvarna Viking Model number 545 and still have problem with it not seeming to get the message to run.
I just got a great answer to the same question. If you are sure the cord is conducting electricity it may be the contacts in the machine. Check for lint on pins. If they wiggle a little you may have to remove back and tighten the screws that hold the machine wires in place.
Sep 11, 2017 | Husqvarna Sewing Machines
How do I find a foot pedal for a Viking Vanessa model 5610 with a power cord?
The part is no longer available from Viking. However, you might be able to buy a used one on ebay or from sewing machine parts. However, you might try contacting some of the Viking stores to determine if they have a used one from a machine they use for parts. You can send me a private email and I'll give you some Viking dealers you can contact. email: deborahcha@aol.com
Oct 15, 2014 | Husqvarna Viking 1
Why isn't my viking 940 push button switch turning on?
it may be broken or your machine may have other electrical problems. Have your authorized Viking repair dealer troubleshoot the machine.
Jul 06, 2014 | Husqvarna Viking 1
Viking sewing machine 940 foot pedal not working
the plug to the machine could have a problem or the or the plug to the
foot pedal could be faulty or the foot pedal itself may need to be
replaced. the machine should be checked to see what is wrong.
Apr 09, 2013 | Sewing Machines
I need a copy of manua/handbookl for Viking 940
http://www.tradebit.com/filesharing.php/search/0/husqvarna+viking/0/1
Jun 15, 2010 | Husqvarna Sewing Machines
Viking sewing machine 940 needs spare parts circuit board and ballance hand wheel
Certified Viking parts are only available from an authorized Husqvarna Viking dealer. However, there are some third party parts companies online. You should be able to find these using Google Search. However, I strongly recommend you have the machine serviced through an authorized Husqvarna Viking dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 09, 2010 | Husqvarna Viking 1
Part for a Viking 6440 Sewing Machine
Check ebay. They sell a lot of parts and/or machines for repair.
Mar 09, 2009 | Husqvarna Viking 1
My viking 990 sewing machine just stop running can you help
Mrs, Clark
It may need a new board or a new transformer. those are the two possible items that usually cause that. It could be a motor but I dont ever see that. It could also be if you wiggle where the cord goes inif it works, there a broken solder connection on the transformer board (repairable witha soldering gun) and fixable.
Kent
Jan 19, 2009 | Husqvarna Viking 1
Feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Oct 27, 2008 | Husqvarna Viking 1
Sewing Machines Logo
529 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
