Question about Alpine CDE-9872 Car CD/ MP3 Player
Face won't stay on
I removed the face once. Now I can't get it to stay on. It's seems to be seated properly, and no pieces are broken, but as I drive, it pops off within thirty seconds.
You need to see which side you are puting it on
Posted on Feb 09, 2009
Seat back won't stay up
Probably has a broken or jammed lock When you position the seat try pulling/pushing the handle instead of relying on the spring to engage the lock. If the seat frame is broken remove it for repair or replace with another seat back
Feb 22, 2013 | 1998 Toyota Corolla
The face wont stay on the stereo due to it not
use a bit of blue tack, this give you a quick fix untill you can repair
Jan 29, 2010 | Car Audio & Video
My Keurig pot will not stay on, nor will it get "ready to brew"
Mine just started doing the exact same thing today. I just bought it a little over thirty days ago. I called Keurig {1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week}
They are sending me a whole new unit (3-10 biz days) and told me to discard my old one. Said it was a problem with the internal water heater so it powers down automatically after it fails.
It typically makes a boiling water sound after brewing as it heats the next batch of water... that is where it is failing in mine.. and yours as it seems. You can call and see if yours is still under warranty and possibly get a replacement unit. Serial number is on the face of the unity behind the drip tray on the front. It's long .. three sets of numbers and letters.
hope this helps
Dec 19, 2009 | Keurig B60 Coffee Maker
My door chimer won;t stop ringing it;s driving me crazy help
Look for the plunger coming out of the frame where the door hinge is. Is it broken? When you open the door the plunger is released (comes out) and grounds sending the signal to chime, however this should only happen if your lights are on or key is in. The chime controller may have failed and that's why it also could stay on. Does it happen when the key is in, while driving, or even always stays on? Need more info.
Dec 13, 2009 | 1996 Dodge Stratus
I have a kitchenaid stand mixer which kept slowing down and finally wont start at all.i replaced the bushes but still it wont start help!
Hi CHESTERMALPA, I hate it when that happens. It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature’s commutator. The concave contact face should be resting completely on the commutator. If you've turned it 90 degrees too much, it won’t' seat properly and the motor doesn’t get any juice.
Good luck, I hope this helps. Howard, Burke, VA\
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 05, 2009 | Food Mixers
Kitchen aid k45ss classic unscrewed black plastic screws and springs on housing and replaced and now it won't run
Hi, JDMCIN. I hate it when that happens. It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature’s commutator. The concave contact face should be resting completely on the commutator. If you've turned it 90 degrees too much, it won’t' seat properly and the motor doesn’t get any juice.
Nov 26, 2009 | KitchenAid K45SS Classic Stand Mixer
The heater in my 1998 Lincoln Mark VIII LSC doesn't get warm. The fan works and the AC works, just no heat. How do I fix it?
You have a problem with your blend door actuator. Every year, twice a year, my husband manually moves the blend door actuator and puts a tie wrap on it so it will stay in either the heat or cool position. You can reach this through the glovebox, which you will need to remove. I had this fixed at the dealer once long, long ago - very expensive because the plastic piece that needs replacing means they must remove the seats and the whole dash area including the steering wheel to properly replace what is broken. If you want to see how that is done go here: http://www.mechanixtrix.com/Article/Article.aspx?ArticleID=145 Much easier going through the glovebox.
Nov 20, 2009 | Lincoln Mark VIII Cars & Trucks
Hp 3600 dn
Open the toner cover remove the toners then shine a torch where the toners push into the printer, from what a remember on the right hand side the black plastic breaks and you should find little pieces stopping the toners from seating properly in the printer. You will also see a wire contact hanging from each broken toner seat. Once you remove the broken bits of plastic and reseated your toners the printer should work as normal. HP have produced a mod for this problem but to be honest the printer should carry on working fine without it, there is nothing to worry about the dangling wires as the toners are earthed from the other side.
Feb 06, 2009 | HP LaserJet 3600dn Printer
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Alpine CDE-9872 Car CD/ MP3 Player Logo
46 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
