Question about Whirlpool GHW9100L Front Load Washer
Whirlpool Duet won't stop draining
I have a less than 2 year old front load washer that fills with water, starts the cycle and than immediatley starts to drain while washing, resulting in a F21 error code because it won't stop draining on it's own. I have tried every cycle, same result. Please help, I have 5 kids, no washing machine!
  • d_dulmage Feb 17, 2009
    If you have this problem, replacing the pressure switch should fix it. It is not what the service manual recommends, however, we took a $45 chance based on online troubleshooting and it fixed the problem in about 30 seconds!
    President:
  • 1,197 Answers
The F21 error on this line of washers is the machines way of saying the water took to long to drain from the tub. This could be a problem with one of the washer parts including the drain pump itself, how the drain hose enters the stand pipe, or maybe even something is stuck somewhere in the drain system and is preventing the water from flowing properly. Not quite an emergency, but it is an indication of a problem and a problem that can lead to something bigger if not looked into.
In talking with the customer, I found out the last load before all this started to indicate a problem was a rug from the house. Rugs can be troublesome to was as many of them used in laundry and bath rooms have rubber backings that can come loose when washed. When the backing comes loose, it can find it's way into the drain system and cause a problem, or the rug fibers can come loose and do the same thing. Figuring this was the problem, I explained to the customer how to get access to the drain pump by removing the three screws that hold the lower access panel in place. Here you will find the pump and the all important sump clean out, or as we like to call it, the coin catcher. Inside she found many fibers from the rub along with a few other things that found there way out of her kids pants pockets.
With the sump cleaned out, I asked her to try another load then to give me a call and let me know how everything worked out. A phone call a couple hours later told me the problem had been solved, and now this customer knows a bit more about her washer.
Many of the front load washers on the market have a user accessible clean out for just such an occurrence. Just be aware that if you open it up, any water that is still inside the tub will quickly be in your lap, so plan accordingly.
Posted on Aug 30, 2010
Wfw9150ww00
Make sure your washing machine is on level ground, if the machine is off balance it will stop.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool wshser-dryer: water won't drain, cycles won't start
You need to give more info in order for a diagnosis. Is this a compact stack unit or an all -in -one unit or an interconnected washer/dryer pair ? Is it front load or top load washer ? What do you mean by "dry cycle"? Is that dryer cycle or is it washer cycle without water ?
Usually when water cannot be drained it is a bad coupling connector on the motor drive, or a bad or clogged pump (small socks have been known to get sucked in an lodged in the pumps); in either case you need a good mechanic or a service person to handle the repair because it requires opening up the shell of the unit and getting to the motor/pump assembly.As always, disconnect the power cord before diving into the unit. Good Luck, Macgivor.
Sep 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F28 error - does not drain
She is no longer having the problem - turned it on and it went through all the cycles - possibly a reset.
Thank you
Nov 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Keeps filling up with water
Hi, the water valve is defective, to make sur unplug the washer 117 electrical corde from the wall and look if it still fill up, if yes then u can be sure that the inlet valve is defective, juste replace the valve and ur home free.. wish u well, Alain
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
235 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
