Question about PW Calpump Pw5500 Waterfall Pump 5750 Gph 3/4 Hp
Pw5500 Calpump not working
We have a pw5500 Calpump waterfall pump that is only 18 months old. It works for a couple of minutes then trips the ground fault plug. I called Calpump and they told me it had water in the motor. When I stated that it was supposed to be a submersible pump I was informed that it could be a number of reasons and I should just buy a new pump. We really don't feel like buying a $179 pump every year and a half. We had a Little Giant pump that lasted 9 years but wasn't big enough for the pond expansion. Can anyone help?
  • Anonymous Mar 14, 2009
    I have the PW2500...same problem after 15 months. I would love a pump that lasts for more thean 2 years. I don't think I'd increase the amps in the breaker.... they are there for a reason...
  • Anonymous Mar 27, 2009
    CalPump PW 5500 lasted eight months -Died sometime during the night - reasons unknow - not plugged, not dry - just died! These are worse than disposble diapers!
  • 547 Answers
Replace the breaker with a higher amp breaker . Thank you for useing fixya please take the time to rate me
Posted on Feb 12, 2009
  • fixit dummy Nov 05, 2010
    You cant increase the breaker size with out changing the wire size, not only that, the breakers are not tripping, the ground fault is. Have a 100 amp breaker..the ground fault will still trip. This was a stupid suggestion.
The waterfall is not working. How can I fix it?
To give you some advice about how to fix your waterfall probably you should specify your equipmente.
Now, without knowing a word about your system I guess the problme is the motor of your pump. If you have no experience repainng the electric board of a pump you should call an authorized repairmen
Jul 08, 2015 | Pool & Spa
Vs pump trips breaker. single stage 1 1/2 pump works fine, does not trip
is motor getting hot if so need new motor also check to see if wires on the back of the motor are loose or the wires to the breaker loose if they are ok you need a new pump motor or pump sometimes a whole pump is cheaper than fixing the old one
Jun 01, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
I purchased an INtex 9 x 18 Rectangular Pool less than a month ago. Th "all in one system" works fine when you select the "FP" (Filter Pump) cycle. However when you switch to the "salt water system" cycle...
Service light is not fixable by the consumer
you will need to call intex
they will e-mail you a form fill it out and fax it back to them
you will have a new pump in a few days to your door
it must be under 2 years old and you must have a valid receipt
Aug 29, 2010 | Intex Automatic Salt Water System for ...
No power
Most of these pumps have an internal thermal switch. It may have tripped and will reset atomaticly
Jul 06, 2009 | Hayward Pro Series 18" Above Ground Pool...
Ebara dominator 1hp automatic pump 110v blows circuit
Try to relocate the position of the pump where it would be protected from water splashes. The pump motor casing might not be designed for outdoor use or not desirable for water splashes. You may also replace your pump with units designed for this purpose (pump with motor casing rating of IP 65 or IP 55).
Jun 06, 2009 | Plumbing
PW Calpump Pw5500 Waterfall Pump 5750 Gph 3/4 Hp Logo
634 people viewed this question
Top PW Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
Are you a PW Garden Expert? Answer questions, earn points and help others
