Question about Dell E151FP 15" Flat Panel LCD Monitor
Dell Monitor 15"flat panel-2 Horiz. black lines
Out of warranty monitor. couple of weeks ago I turned on my computer and there were 2 "brushed stroke" black lines from right side of monitor.both appears like was painted on inside of glass. one is 1/4 way, the other is1/6 way across monitor. Any suggestions?
  • 1,602 Answers
HAS IT HAPPEN ANYMORE OR IS STILL THERE.
CHECK YOUR DRIVERS, UPDATE THE DRIVERS, CHECK THE CONTROL PANAL IN THE FOLLOWING FOLDER DEVICE MANAGER, PROBLEMS REPORT, SYNC CENTER
OTHER THAN THAT TECHN SUPPORT OF YOUR VENDER WHERE YOU BOUGHT YOUR MONITOR FROM OR GO ON LINE AND TYPE THE FOLLOWING INFORMATION EXAMPLE:
DELL E151FP FLAT PANEL LCD MONITOR 2 BRUSH STROKES ON SCREEN
ENTER
SEE IF ANYONE ELSE MAY OF HAD THE PROBLEM OR TO COME FIND OUT THAT THAT WAS A RECALL ITEM FOR THAT MONITOR, JUST KIDDING, ITS WAY OUT THERE
ROD
Posted on Feb 09, 2009
MONITOR ISSUES
There could be a problem on the monitor itself if it frequently turns itself off, try to unplug the VGA/ DVI cable and check if you can see the self test feature. If not, the monitor needs to be replaced. If you are still covered by the warranty, just call dell and they will replace it for you. Hope this helps
Dec 14, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell 17inch flat screen monitor will not remain on, the screen go
If your Dell monitor still under into warranty, better to call Dell technical support and have them replace your monitor coz there is no way you can fix on it.
If the monitor is beyond with the warranty already, better to but a new one than taking it repair that will cost you much.
Thank you.
Oct 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
15" HP Pav. monitor turns on for a second but immed blacks out
Pls ask your dealer about the warranty..It depends as per the market.. If the light is comming then replace the AD card other wise The problem with the inverter card.. replace ...
Jul 06, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
My monitor do not work right
Are you saying that you can faintly see your desktop or just the reflection of your desktop??
if you are saying you can faintly see your desktop it means that the fluorescent light isn't firing up properly, take it to a repairman or if its under warranty, take it back for a swap or a refund.
Mar 24, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Black screen monitor
souns like the dc-dc convertor board that supplies the backlight gone faulty possible poor soldering on board
Oct 07, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Dell 21" M1110 .22DPI 1600x1200 *SUPER...
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor goes black
it depends whether it displays anything. There's only one fuse which determines if the power is on or nor. If your monitor turns on, I would not look for the bad fuse.
Sep 29, 2006 | Dell E151FPp 15" TFT LCD Flat Panel...
Dell E151FP 15" Flat Panel LCD Monitor Logo
123 people viewed this question
Alun Cox
