Question about Tomtom GO 510 GPS Receiver
Resetting my tomtom GO 520 needs reset but iv lost instructions ...
    An expert whose answer gotĀ voted for 100 times.
  • 171 Answers
To reset your tt 520 use a straightened paperclip and insert it into the reset hole on the bottom of your tt 520 for 20 seconds.
Hope this helps
Posted on May 11, 2009
Cannot turn on my tomtom 520
go to, go to support, search for reset, select your device do as told. includes fotos of resetbutton and good discription. first make sure battery is full. goodluck.
Oct 12, 2009 | Tomtom GO 520 GPS Receiver
Tom Tom Go 520 Wont connect via USB
It sounds like your mini usb connector is damaged. If you're handy you can buy a replacement and solder it in. You will need a very fine tip soldering iron and a magnifying glass. The repair can be quite challenging as the components are surface mounted.
Otherwise I can fix it for you for a small fee.
I've repaired about 20 tomtom units with similar problems. I charge around £35 for this including return postage
Sep 06, 2009 | Tomtom GO 520 GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Restarts unexpectedly and slow to start
The TomTom 520 and 720 are the same unit. the differance is the maps. The 520 has maps of the US and the 720 has maps of Europe. Download the free clearflash utility from TomTom and run it a couple of times. This should clear up your problem. Sometimes the mapset config in the map gets full and it has to be cleared.
Jul 20, 2009 | Tomtom GO 720 GPS Receiver
I have the tomtom go 520,i have changed my computer and have lost my set up disc,can i download the drivers so i can update my unit
Tomtom uses the generic usb drivers. You can download tomtom home from the download section of the tomtom website
Jul 11, 2009 | Tomtom GO 520/720 Remote Control
Lost activatoin code for 520 tomtom no help
Go to this site for your map problem.
Apr 17, 2009 | Tomtom GO 520 GPS Receiver
Tom tom home does not see my tom tom go 520
Hi canal_boat_m
Try this solution:
STEP 1 Un-install Tom Tom Home from your PC
STEP 2 Click on the link below:
This will download a little removal program for the Tom Tom Home program.
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 3 Visit Tom Tom website and download the current new version of Tom Tom Home and install it to your PC
STEP 4 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
Your Tom Tom should ask you to 'Connect to Computer' if it does tap YES.
Your unit should now be recognized by your PC.
IF IT DOESN'T then follow the instructions below:
1. Connect your unit to your PC;
2. Copy two folders to your PC (namely 'Raster' and the one which holds all your maps - probably called 'United Kingdom and Eire';
3. Using Windows Utility, right click on the Tom Tom drive unit and select Fomat;
4. Switch off the unit and soft-reset it with a paper clip (but hold it in for at least 20 mins) and then re-connect it and power it up;
5. Tom Tom Home should now detect the unit and your unit should ask you to 'Connect to Computer' so tap YES;
6. Tom Tom Home will now say your device needs updating - and if you apply all the changes it will restore it to Factory Finished!
7. Then all's needed is to replace the two folders you backed up and any other items like mp3's and sounds, pics, etc.
Feb 27, 2009 | Tomtom GO 520 GPS Receiver
Tom Tom 520 Reset
thank you for using
click on this site you be directly connected to the manual including to solved your problem how to reset your unit geneal..
hint go to page 39 of the page GENERAL Reset guide.
please don't forget to rate our answers.
Feb 19, 2009 | Tomtom GO 700 GPS Receiver
Problem with tom tom 520
Do a soft reset by holding the power button down for 15 seconds. then power on and off. it should work. It did for me. if not, call tomtom. they are willing to help quickly
Feb 09, 2009 | Tomtom ONE GPS Receiver
GPS Logo
187 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
