Question about Microsoft Xbox 360 Console
Same as the last, Just updating it.
The solution suggested did not help. I bought new HD cables. that didnt help then i bought a HDMI cable and that didn't help. I went through all the regular steps checking the attached devices.No help. It is something internal.
    Problem Solver:
  • 10 Answers
The port in the back of your console is damaged and you will either have to replace it or send it off to microsoft and they should fix it for you
Posted on Feb 10, 2009
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
My ps3 was switced to hd and wont switch back to a av cable
You have to set it back to the regular cables the same way you did with the HDMI
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Jan 27, 2010 | Televison & Video
No HDMI signal
The Dvd player is not sending a High Definition signal,You may be able to change the output to high definition.
Please rate this a fixya
Feb 01, 2009 | Televison & Video
I have Time Warner cable. I just bought a new Sony LCD HD tv and the sound and the video are out of sync on some channels - HD and non HD I am using a HDMI cable. Any solutions that you know of?
Yes there is a simple solution. First, for some reason., Time Warner cable boxes have SERIOUS HDMI issues, including no pic, intermittent pic and sound and the one that you are having. The easy fix is to hook the TV to the cable box using the component connections instead of the HDMI. Normally I would suggest getting the cable box replaced, but I have seen customers exchange cable boxes 3 or 4 times and still have the problem or have a new problem. Use the component connections and be sure to let me know if this works. If it does, be sure to rate this solution. Thanks!
Nov 09, 2008 | Televison & Video
Hdmi and audio
It may be the top of set box.. Most times the sound and picture are auto detected by the set when HDMI is used. Both sound and video are carried in a HDMI cable but not with a S video cable. Try another HDMI cable *** dont buy the expensive one the tv don't care if they cost $125 or $25.
May 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Apr 08, 2008 | Bose Lifestyle 28 System
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
