Paper jam in laser jet 3800
Error message is 13.01. I can feed paper in one page at a time in tray one. Some people say it needs to be cleaned. What and how?
tray 2 roller will not catch paper properly.
  • 1,602 Answers
THERE CAN BE OIL FROM YOUR HAND OR FROM THE PAPER YOU USE OR THE TYPE OF PAPER YOU USED, THE ROLLERS CAN MATERAIL OF SOME SORT ON THE ROLLER NOT ALLOWING ENOUGH GRIPPING OR PRESSURE TO PICK UP THE PAPER, CLEAN THE ROLLERS WITH PAINT THINNER OR ALCOHOLA, BLOW OUT THE DIRT AND DUST FROM TONER CARTRIDGE BE CAREFUL NOT TO BLOW TO HARD AND DESTROY THE TONER CONTAINER, OR OTHER VITAL PARTS IN THE MACHINE.
OR JUST BUY A NEW MACHINE MOST ARE A TIME A DOZEN ANY MORE.
ROD
Posted on Feb 09, 2009
ERROR MESSAGES ON HP LASER JET 1536DNF MFP jam in cartridge - there is no jam
Check to see if the paper is feeding, should be feed some what into machine, if not paper is not getting to cartridge and showing a jam... some times clean wheels with water or windex
Mar 28, 2017 | HP Office Equipment & Supplies
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
13.20 but no paper jammed in path hp9500n ( col laser jet not mfp 9500..).. c8546a.printer boots and immediately gives 13.20 remove paper jam. cleaning page passes through ok when doors are closed...
Open tray 4 and the right
side door to check for
jammed media. Check the paper path
between tray 4 and the
printer. Check the tray-size
guides. Replace the pickup,
separation, or feed
rollers. ur problem 100% resolved
Feb 09, 2010 | HP LaserJet 9500n Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
My LaserJet4250n Printer keeps printing a page recurrently. Except the former job is cancelled Manually, it prints the previous instead of the currently sent job. Moreover,it displays the following...
I think what is happening is when you get the error, the printer automaticaly reprints the page it was on when it got an error condition that makes it think it didn't print the page correctly. The clearing paper path message comes up after it thinks it had a jam. Displaying load plain paper could be because either the printer is not configed for the correct type of paper you have in the tray you are trying to prin form(push the green check button, arrow downt to paper handling and see what your trays are set for.) Also there is a blue switch on the tay(looking for front of tray it will be on the right hand side of tray rail) the switch says standard or custom. The switch should be in the standard position.
Are you getting any errors or jams, if so, tell me what they are.
Feb 25, 2009 | HP LaserJet 4250n Printer
295 people viewed this question
jasbo
jasbo
