Question about AT&T E5812B 5.8 GHz Twin Cordless Phone
Phone reads: Other Handset is on or out of range
But they are not...Please help
I faced the same problem. Someone help!
Posted on Jun 01, 2010
  • 15 Answers
SOURCE: Out of Range
Make certain that the phone line cable is plugged securely into the base unit in the back. Disconnect it and re-insert it into the connector firmly. That should do it if the battery pack has been sufficiently charged.....12-16 hours should do it for the initial charge. Of course, you can't ecxpect it to find the base unit if it is 2 miles away, under a metal box! Just kidding!!
Posted on Dec 29, 2007
coolcat_12
  • 259 Answers
SOURCE: my handset reads "out of range" but it is sitting on the base.
It could be faulty phones or try replacing the batteries
Posted on Jan 10, 2009
SOURCE: My handset reads "out of range"
Hi, I know its a few days later than I wanted to respond, but now I am. I try your method, but I went back to the formula I mentioned in my problem, and I had missed one whole step. So I started over and followed the formula exactly, (which was to remove the battery completely from the handset). I skipped over that completely the first couple of times, but when I did it, it worked like a charm. But thank you, because it was the "buy a new battery" suggestion that gave me the idea to try my formula again.
Posted on Jan 16, 2009
  • 240 Answers
SOURCE: Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Posted on Oct 03, 2009
  • 5262 Answers
SOURCE: just brought the phone charge
First check if the battery is properly connected/installed. It's possible for the connection to be loose. If this is your situation, recharge the handset again. Then try again.
Next make sure that the base has power (plugged into a live outlet). With a regular corded phone, make sure that the phone line is working. (Make sure that you get a dial tone.)
If the unit is new, you may want to contact Uniden. The battery may have degraded over time in a warehouse. If you bought the unit used, try a new battery.
I hope this helps.
Posted on Aug 14, 2011
Why is handset reading out of range? OR searching?
THAT HAPPENS WHEN YOU DROP THE PHONE TOO MUCH.
THE SOLUTION IS TO TURN OF THE BASE FOR 2 MINUTES.
THEN REMOVE ALL THE PHONE BATTERIES. ALL OF THEM
WAIT FOR MINUTES,
PUT THE BASE BACK FIRST, PUT ALL OF THE PHONES BATTERY BACK
PRESS THE RED BUTTON, YOU WILL SEE THE "OUT OF RANGE RANGE" MESSAGE AGAIN.
IGNORE IT AND PRESS THE GREEN BUTTON. HERE YOU GO.
MAKE SURE TO CHARGE IT AFTER THIS.
PLEASE RATE IF THIS SOLVED YOUR PROBLEM
Apr 12, 2011 | Uniden DECT 6.0 Cordless Phone ID
Phone message reads
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Mar 08, 2009 | Uniden TRU8885-2 Cordless Phone
My handset reads "out of range" but it is sitting on the base.
Jan 10, 2009 | Uniden Cordless Phone
Phone keeps showing out of range
If your handset is reading out of range. Check the the main base and make sure you unit has power. This can be done by placing the handset in the main base to see if the charge in use light comes on.
If your main base isn't getting power please make sure the ac adapter is plugged in and is warm to the touch. If not the ac adapter would be damaged.
Follow the below steps with the handset to solve your problem.
Press and hold the End key down and hold it.
Press and hold the # key down and hold it.
While pressing each of these keys down in order wait until the handset reads deregistration complete is seen.
Then release the keys and place the handset on the main base to register the handset.
Dec 03, 2008 | Lands Phones
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
Panasonic cordless phone with answering machine model number Kx-TG2632 2.4 gigga range I miss place the book and I need help to adjust the volumn thank-you
The message on crystal reads"no link to base. Move closer to base, try again". I put in a new battery in each phone and not sure if they are charging. i keep getting the same message. What is the problem and how do I solve it?
Thanks
Dec 02, 2007 | Panasonic KX-TG2632W Phone
AT&T E5812B 5.8 GHz Twin Cordless Phone Logo
104 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
