Question about Minolta magicolor 2400W Laser Printer
Konica Minolta magicolor 8650 invisible on the network
I have a Konica Minolta mc8650 printer, and I'm using it with a mac pro (intel) with OS 10.5. I was using the printer via USB, and it was working perfectly (driver is installed properly). Than, I tried to set it up on the internal network, with Bonjour, and it was working from my mac pro, and from the other G5 with OS 10.4 on the network.
The only thing was that it was accessible by anyone, (public access) and I don't want that, so I set up the user settings on that browser interface, where you can set the settings for the printer from your browser. I created a user with a password, and I tried to print, but it just didn't print. The printer queue processed the job, than it said, that it's done, but the printer did nothing. and the same with USB. so I set back the settings so it had public access, and it was working fine. I did this back and forth a couple of times, to figure out what's wrong, but after when I set it to username and password again, the printer would't apperar in the list of the Bonjour printers anymore. and I couldn't connect to that HTTP interface again, it doesn't find the address. so basically I can't access my printer. and the weird thing is, that when I try to use it via USB, the printer is visible by the computer, but when the print queue processes the job, than says that it's done, the printer doesn't do anything. So it doesn't work with anything. (I also tried IP printing, it says, that it can not connect to the printer.)
Please help, I called Konica Minolta 5 times so far, and they couldn't help yet...
  • Minolta Master
  • 6,400 Answers
Nitrotrike
  • 589 Answers
SOURCE: Hi. I have a Konica
It is under the Administrator Menu:
From an Idle state, Press:
Menu
Next - you should see "configuration administration" on the display.
Press the left or right arrow key until "Administration Startup Options" is displayed.
Press "select"
Press the left or right arrow key until "do start page" is displayed.
Press select.
Press the left or right arrow until "no" is displayed.
Press "online" (save changes *no? should be displayed)
Press "next" (right arrow) "save changes? yes" should be displayed.
Press "select" to save settings.
Press the select to reboot the system.
This came directly from the operators manual, and may differ depending on the firmware version of your machine. If this does not work, please let me know and I will research it further.
Posted on May 25, 2008
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 3 Answers
SOURCE: Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Posted on Aug 11, 2008
  • 118 Answers
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Posted on Nov 18, 2008
SOURCE: question about mc 2350 cartridge
I just got done replacing my toner.  You'll need to change toner and most likely all of them. There is no other solution.  I refill mine by buying the bottle toners.  It can be messy and you'll need to take some parts off the cartridge to get to the opening plug and reset the lever so that the printer knows the cartridge is full.  It is cheaper than buying a toner. The cartridge has a life of about three refills.  Anyway hope this answers your problem.
Posted on Nov 19, 2008
Mac magicolor 330
Konica Minolta web site does not even list that machine under discontinued very old and you want to use a MAC with it. Try this ite Self Help Product Support Konica Minolta Business Solutions Inc
May 16, 2014 | Genuine Konica Minolta Konica Minolta...
Magicolor 8650 polygon motor
Polygon motor is located inside the print head along with the LASER
Apr 30, 2014 | Konica Minolta Konica-Minolta 4599161...
Konica Minolta Magicolor 8650 C4153 error
replace the yellow print head which houses the LASER for the yellow drum print head is located below the yellow image unit (each color has one). It is a "######" to get out, recommend a tech do this.
Feb 17, 2014 | Konica Minolta magicolor 8650DN All-In-One...
If I download drivers for my Macbook for Konica Minolta 290MF will I be able to print from my macbook pro?
You may need to download the drivers for the 2590MF instead as there is no Mac drivers available for the 2490MF, but you should be able to use these drivers:
Go to this link
http://onyxftp.mykonicaminolta.com/download/Search.aspx?ht=
Select
Desktop Printers
Magicolor 2590MF
Drivers
Select your Mac OS
May 23, 2011 | Konica Minolta magicolor 2490MF Laser...
Konica 7140 gives error code fs516 what is this
FS -516 is the finisher that part of the copier that staples hole punches etc,
Apr 21, 2011 | Konica Minolta Konica-Minolta 4599161...
I have no driver and can't load a driver for My Mac OS X 10.6.6 for Konica Minolta magicolor 1690MF
Open this LINK, scroll down the page to the section called "Mac OSX 10.6.X - Drivers" and download your drivers. Hope this helps. Good Luck.
Thanks for using FixYa.
Mar 02, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Minolta magicolor 2400W Laser Printer Logo
339 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
