Question about HP Photosmart M305v Digital Camera
When I down load the hp photosmart m305v digital camera
The computer says it cannot find this camera. I have uninstalled and re-installed it twice to no avail
  • 10 more comments
  • Sonny Fields
    Sonny Fields Feb 09, 2009
    windows xp
  • Sonny Fields
    I use windows xp
  • Sonny Fields
    Sonny Fields Feb 10, 2009
    Ok I'll try in the a.m. I sure hope that works!!!
  • Sonny Fields
    Do I reinstall the program?
  • Sonny Fields
    Ok, I did what you said step by step and when I pluged in the camera on, to the usb cable, nothing happend. In my computer it shows the type of camera but there is no data next to it like the other things that are in there
  • Sonny Fields
    Sonny Fields Feb 12, 2009
    Ok, I'll try that. Something weird is happening. Now my printer won't work either. AT&T came and installed AT&TUvers and dis connected Direct tv. Do you think that it could have anything to do with my problem? But I did use the printer after installation.
  • Sonny Fields
    It acts the same as the camera. It acts as if no signal is being sent to it.
  • Sonny Fields
    I followed your instructions but still nothing.The test page says[status]-Error- printing [size]-80.7 KB
  • Sonny Fields
    How can I find out if the USB card is good. It has four ports.
  • Sonny Fields
    I don't have another device there all down
  • Sonny Fields
    Sonny Fields Feb 17, 2009
    My Printer, Camera and scanner all show in windows that they are downloaded but when I try to open any of them it say's that it can't find that item!!
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    What operating system are you running on the computer in question?
    President:
  • 778 Answers
Uninstall the camera software, reboot the computer, wait a couple of minutes after your desktop appears, then connect the USB cable with the camera connected and powered on. You should hear a wave sound indicating that the device is connected at which point you should be able to find the device in "My Computer" and treat it as any memory storage device.
I hope this helps.
Posted on Feb 10, 2009
  • 4 more comments
  • Frank  Fernandez
    Frank Fernandez Feb 10, 2009
    Good luck, and if it doesn't work post back and we'll figure it out.
  • Frank  Fernandez
    No don't run the setup from the CD, but you may leave it in the CD tray so that Windows may retrieve the driver if necessary.
  • Frank  Fernandez
    Frank Fernandez Feb 11, 2009
    Ok, the camera is displayed in My Computer. Now you just right click on it and open or explore and you should be able to transfer pictures. Make sure the camera batteries are charged and the camera is turned on. If it's displayed, Windows recognizes it.
  • Frank  Fernandez
    Frank Fernandez Feb 12, 2009
    I don't think the AT&T install would cause any problem. What is the problem with the printer?
  • Frank  Fernandez
    Please try to print a test page (you can just type "test" in notepad and select print under "File") and make sure you point/select the correct printer when the print dialogue opens, then print. The default printer in windows will change for whatever reason and trying to print while pointed to another application or device will do as you describe.
  • Frank  Fernandez
    If windows is listing your printer when the dialogue pops up then your USB card is probably good. You could connect another known working USB device and see if it works to make sure though.
Hp photosmart e317 digital camera downloads for windows 7 operating systems
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program, such as Picasa.
Feb 19, 2012 | HP Photosmart E317 Digital Camera
Cant upload pictures. says "cannot find pictures". This is while I have camera plugged in and on. Whats up? also can I uninstall all HP and reinstall with HP Photosmart M307 Digital camera cd got with...
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 05, 2010 | HP Photosmart M415 Digital Camera
My HP Photosmart M407 digital camera won't upload photos. I've uninstalled and reinstalled the Image Zone software several times. It comes up and freezes.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Nov 06, 2009 | HP Photosmart M407 Digital Camera
HP Photosmart (Touchsmart) corrupts Windows XP
try to completely scan your computer with good antivirus. Uninstall Photosmart and make sure you have completely remove it.Delete the Photosmart's folder remained in c:\Program files. After, install again your printer.
Oct 22, 2009 | HP Pavilion a6700f PC Desktop
Not seeing on computer Trying to down load pictures
Download HP Photosmart software from www.hp.com under Software & Driver Downloads for R707. You can download your photos by setting your camera USB Configuration to Disk Drive in Setup Menu.
Jul 06, 2009 | HP Photosmart R707 Digital Camera
When I bought camera I had Windows XP. New computer has Vista.
So you now have Vista, but the software will not load...
If you have Windows Vista (32-bit), click this link and download the "HP photosmart software and drivers" package. Install by directions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=1154651&lang=en
If you have Vista 64-bit, use this link. Download the "HP photosmart software and drivers" package. Install by directions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2100&lc=en&dlc=en&cc=us&product=1154651&lang=en
I hope this helps you, don't forget the "FixYa" rating if this solves your questions!
Apr 03, 2009 | HP Photosmart R725 Digital Camera
1.loaded software which came with my photosmart C5280,but icon does not appear on PC screen and I can't access my manual. I have uninstalled software a few times and re-loaded, but same outcome. USB...
fredwilliam- this unit comes with the photosmart essentials software and according to hp this is a low end photosmart... the software might not be getting installed correctly due to insufficient previlages on the computer for your userlogin. Download and run the software three times from the following link from hp http://tinyurl.com/5u2pg then uninstall and install again. If you have had another hp camera or printer installation remove that before you reinstall.
I hope this helps!!
Oct 10, 2008 | HP Office Equipment & Supplies
Fatal error installing photosmart E327 digital camera software
if this is in your computer, please uninstall the software, if in case your computer does not allow you to on normal OS operation, boot your computer to safe mode, access add remove programs then uninstall the camera software.
if in case before you perform the uninstallation, please download the same UPDATED software from HPs site if it is available.
Aug 12, 2008 | HP Cameras
Down loading my photosmart R727
To download images to your computer, simply plug in the usb cable into the camera. Then plug the other end into your computer. Then you can download pictures by going to Start>Computer. Then double click on your camera. Go into DCIM. Double click inot the folder and start copying files to your computer. If you have an SD card reader, you can just plug the card into that and you can access your files through that instead.
Nov 25, 2007 | HP Photosmart R727 Digital Camera
HP Photosmart M305v Digital Camera Logo
23 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
