Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Corrupting my files
I noticed that when I first got my Cruzer Micro USB 2.0 Flash Drive it corrupted a few of my files in Microsoft Word when I copied them over from a disk to the flash drive. I was concerned but since it didn't affect my Excel files or pictures I let it go figuring it may have something to do with the XP conversion within MS Word. I don't use Word as much so wasn't that concerned. Since then it has corrupted a few of my Excel files to the point that they can't be recovered. I am following all the appropriate disconnecting procedures. What would make this happen?
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 02, 2010
Hello, I have Sandisk Cruzer blade 4 gb pendrive. But now it shows I/O error while copying data to it. please give a solution.
Copy all the files from it to your 'C:' drive, and burn the files to one DVD-recordable disk.
Then, responsibly recycle the SanDisk, and spend $10 to buy a new flash-drive.
Copy the files from the 'C:' drive, or the DVD disk onto the new flash-drive.
Keep multiple copies of your files, just in case this "new" flash-drive also "fails".
May 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to copy a doc. file to the flash drive.
Ok. here is what you need to do.
1. Hook your flash drive to any of the usb slot in your computer.
Wait for the system to read it. A green arrow icon will appear in the taskbar to show that a new removable hardware device is connected. After it successfully recognized, It will display a message " The device is installed and ready to use" at the lower right portion of the windows taskbar.
Click on My Computer a new drive will appear. It is usually designated as removable drive. On this drive you will paste the copied doc files. It is the assigned drive for your flash drive.
So go on., copy all the files you need to carry and paste it in the flash drive.
Be reminded also that before you unhook the flash drive from the computer, right click first on the green arrow icon on the taskbar and stop the operation. Click stop on the flash drive. This will turn off the remaining applications / readings in the flash drive and will prevent it from crashing and file corrupting.
I hope you understand.
Please give me some good ratings as this will help me too.
Thanks.
Aug 14, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
What do micro cruzer sandiscs do
your micro cruzer sandisk can perform lots of function .
You can copy your data,songs, video files on your flash drive to use it any time any where .You can do this by just following the simple steps :
1. Plug the USB flash drive to a USB port.
2. A USB flash drive icon will appear on the desktop
3. Double-click on your Cruzer USB flash drive.
4. Select the files or folders you want to copy to the USB drive by clicking on them.
5. Drag and drop the selected files or folders to the USB flash drive icon.
Note : Do not immediately remove your drive from the USB port,right click on drive icon in notification area then click on safely remove the drive ,then remove your drive from your computer.
2: You can take backup of your computer on your flash drive
3.You can also boot from your drive if *********** board support boot from from your flash drive.
May 18, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Thumb drive corrupting my word documents
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
Jan 04, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Corrupt USB File
have you tried using the open and repair option?
1. Start Microsoft Word
2. Go to File menu
3. Select Open and open dialogue box appears
4. Select the file
5. Click the arrow shown on the right side of the Open button and then following screen appears
Thanks,
Lee
Jul 08, 2009 | Electronics - Others
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro USB I/O device error
I would recommend plugging your Cruzer into another computer. It's possible that your computer has corrupted or incorrect drivers for the flash drive. This is one cause of the yellow alert in Device Manager. If you move the flash drive to another machine and it works, you can save your data and make a backup copy. If your Cruzer doesn't work in a different computer (I would try at least 2 other working computers), it's possible that the flash drive is faulty.
May 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Write protect problem
what ever file you have copied or going to copy . right click on the file , go in properties and and uncheck read only. this will solve your problem
Jun 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer micro 2.0 GB problem
my sandisk cruzer micro 1Gb flash drive was not working for a month while i was copying 5o nos of photo on it.If i plugged in my device my pc getting hanged and the flash drive was not detected, please give me solution.....
Jun 05, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
201 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
