Question about Garmin nuvi 350 GPS Receiver
My garmin will not turn on and its fully charged
Please help i had my nuvi on and said searching for satallites for quite a while so i turned it off and now it wont turn back on, i went to charge it even though it had charged hours before and it wont even show that its charging!
what up
  • ajackcash Mar 03, 2009
    My garmin shut off after it had calculated and started the map and now it will not turn on. We tried the wall outlet and computer and it wont do anything?? HELP!!!!
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Does it power on when the charger is plugged in? have you tried pressing the rest button underneath the antenna?
The reset button fixed the power problem. Thank You, Thank You!!!!
Posted on Mar 03, 2009
Garmin nuvi turns off for no reason
This usually occurs when the battery low on power.
If the battery is fully charged, then updating the software will usually help.
This can be done using the Garmin WebUpdater program.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Jan 29, 2012 | Garmin nuvi 1390T Car GPS Receiver
SATALLITE Wont turn on
This is a common problem with the Nuvi 3xx and 6xx series and has nothing to do with the battery. A component has failed and needs to be replaced. Further info on this problem can be found here:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Jan 09, 2012 | Garmin Nuvi 660 GPS Receiver
My gps is not turning on. I tried to charge but there is no signal. Can you please help me?
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 12, 2010 | Garmin nuvi 1300 Car GPS Receiver
Upon turning my Garmin Nuvi 1300 on it sticks on the screen that says "GARMIN".......Loading Maps. It never goes past this screen. I have had this unit since the end of December. It is fully charged and I...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Apr 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
I just got a Garmin nuvi 1300 for Christmas and it has worked just fine for almost 2 weeks. Then yesterday, out of the blue, it shut off for a few hours and would not turn back on. It did the same thing...
I hope that helps.
Jan 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 1300 won't turn on. It should be fully charged as I drove a couple hours with it plugged into my cigarette lighter. Nothing happens when I push the power button. I've had it for not even a...
I hope that helps.
Dec 28, 2009 | Garmin nuvi 1300 Car GPS Receiver
I have had my garmin nuvi 200 for almost a year now and only recently it has been acting up. i have been going the same route for a few days so i have an idea on where i am going and where i need to turn....
your battery is low on power and needs to be fully charged. It may be that your battery needs changing.
DC does not fully charge it and also starting the engine while plugged in will eventually ruin the battery and affect the sirf chip. Charge it on AC or via the USB
Please rate my help++++Thanks for using FIXYA
Dec 05, 2009 | Garmin nuvi 200 Car GPS Receiver
My Garmin Nuvi 200 won't turn on/fully charged
If it is not charged it will not turn on. If you have a bad battery (which is the case if it won't fully charge) your only choice is to return to Garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device. Go here for repair:
http://www8.garmin.com/support/outofwarranty.html
Aug 12, 2009 | Garmin nuvi 200W GPS Receiver
Itnow takes 15 to 20 minutes to locate a satallite no matter what I do. I live in SW Florida &i use a Nuvi 200 which worked perfectly until a few weeks ago. I have used it for less than a year and was...
change the battery or make sure its fully charged when you use it.
Ensure you do not insert it into DC of car when starting motor this will kill battery quickly and even damage the chip
Jun 29, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
Garmin Nuvi 260W shuts off before it fully loads maps
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
425 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
