Question about Samsung Televison & Video
Blue/green g'morning, i click on my TV, it's fine then the screen turns fuzzy then green and blue colors, then it fades back to normal. There is no pattern, to track what may be the problem. Someone suggested the drum needs i do this myself or take it to a cleaner/repair person-place...??
  • 250 Answers
No its the problem of convergence stk ic in your projection tv.and yes you can do it your self if you have the knowledge of using soldering iron. for the step by step instructions you will have to click the following link and read the instructions
but if you find it difficult to do .do not take a risk of doing it it will be dangerous .you can take it to repair center.aS it will not be too costly issue to get it repaired. thanks.
Posted on Feb 09, 2009
My LCDTV has a problem, Model number is 6626LCT, Now on to the problem, While doing yearly cleaning on my tv as normal, after i plugged it in it was normal for 40 seconds, It flickered and the screen went...
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
Jun 06, 2012 | Sylvania Televison & Video
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Blue screen
bad connection but where need tech.
Nov 27, 2008 | JVC AV-27D302 27" TV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Normal pictures fades to blue screen within 30 seconds
The fix for this is here somewhere, as I had the same problem last January and the solution was posted here in March last year. I'll try to find it and post the link to it for you, later.
Nov 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Televison & Video Logo
106 people viewed this question
Jerry Greenberg
Jerry Greenberg
