Question about Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Remote will not turn on/off TV or adjust volume up/down
TV is connected to Cox cable provider. Remote operates channels up and down just fine but not
the on/off, or volume up/down. How do I fix this?
  • lewisw21 Feb 09, 2009
    symphonic model BL519DD same problem
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
swampduck651
  • 5 Answers
SOURCE: can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Posted on Feb 05, 2008
  • 668 Answers
SOURCE: i was watching tv when suddenly the volume control
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Posted on Jul 02, 2009
SOURCE: Same thing! Remote doesn't want to work
Try cleaning the infrared LED on the PC board. I had the same problem (10 year old Toshiba). LED was cloudy with dust- also clean inside the TV where the light comes trhough. Works fine now
Posted on Aug 17, 2009
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Posted on Sep 14, 2009
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
I am trying to program an 8820 cox remote with my olevia tv
Not suprising===not all programmable remotes if they will even program will have all essential features---universal is a misnomer.
Jun 11, 2012 | Olevia LT27HVX 27 in. LCD Television
We've had our 32" Vizio TV for about 4 months now and up until about 2 weeks ago, everything was working fine and all channels came in. Now, we only get about a quarter of the channels that we used to...
go to menu settings, find add/delete channel or programming or tuning. There should be an option that says "autoprogram" select this option and let the program run thuroughly. It will read and install all available channels. Do make sure tv is set to CATV and that it is NOT set on AIR.
Jan 27, 2010 | Televison & Video
Sylvania LC321SS9 remote code
I have the sylvania LC321SS9 tv and a atlas dvr1056 remote code 1864 works great with all functions!
Jan 14, 2009 | Zenith ZEN450 Remote Control
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Sound Issue
Check the cable box volume. Most boxes allow you to adjust the volume from the box to the TV, and most likely it's gotten turned down. Use the "Volume" control on the cable box to bring the level back up. (Unless the box remote has been set up for RCA, it controls the box volume. Once you get the volume back up, follow the cable provider's instructions for setting the remote to control an RCA. Then the volume control will function correctly.)
Feb 22, 2008 | RCA F27440 27" TV
Too many remote controls
Cox / Comcast Remote Control Code 0178
Oct 05, 2007 | Polaroid FLM-3232 Television
Toshiba MW30G71 30 in. TV/VCR/DVD Combo Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
