Question about Lexmark X83 All-In-One InkJet Printer
Usb cable where is the usb cable connection in the lexmark x83 printer?
  • Loida Ibarra
    Loida Ibarra Feb 18, 2009
    Thank you very much for your help.
The USB connection is just above the power connector and to the upper left of the red scanner lock lever.
Posted on Feb 18, 2009
Hi, I have a lexmark all in one printer x83. I also have a toshiba l300 series laptop. I want to know if my laptop is compatible to hooked up to my printer.
How does the printer connect to the PC, via USB?
If it is a USB connected printer then physically the printer will connect.
However, the real question is whether or not the X83 has a driver for the operating system that is on your laptop. Since you did not tell us the OS, I'm dead in the water until you do.
Don
Dec 09, 2009 | Lexmark X83 All-In-One InkJet Printer
NO POWER -lexmark X83
Then you must assume that:
1. Either the AC adapter is faulty
or
2. There is no power from the socket you the device is connected to
or
3. AC adapter is not connected properly to the power socket and the printer
or
4. The 'transformer' inside the printer has blown
Scenarios 1, 2 and 3 are easy. Scenario 4 requires either you return the printer to Lexmark and they repair it, or you purchase another printer. If it's still under warranty, contact them. If it's not, think about getting a replacement from another manufacturer.
Apr 09, 2009 | IBM Lexmark X83 All-In-One InkJet Printer
Lexmark X83 has system error A04.
Try to do the following:
  1. Reseat both cartridges in the printer and unplug the power cable for 30 seconds.
  2. Plug the power cable back in.
If you still experience issues please let me know.
-Serge
Mar 30, 2009 | Lexmark X83 All-In-One InkJet Printer
What printers are compible with Lexmark X83 All-In-One ?
Do you mean what "computers" are compatible with the lexmark x83? Go to : http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X83
to get the latest driver and computer requirements
Jun 14, 2008 | Lexmark X83 All-In-One InkJet Printer
My windows vista Business cannot install my Lexmark X83 All-in-one printer!
Lexmark is not officially making any driver for the X83 that will work with Vista because its a 32 bit printer and Vista is 64 bit. Sounds like some BS to me. So, I have the same problem, a perfectly working printer and an incompatible OS. My Mom was using an old mac and had an X83 printer which she loves. She now has a new PC running Vista. Only now, I have the problem of how to get the X83 to work with Vista. Supposedly the lexmark 5200 drivers will work. My suggestion is to power off and unplug the USB cable to the X83, and manually remove any driver(s) related to it that may have been installed using the system control panel device manager. Then attempt to install the xp driver for X83 per the post below. I'm going to then plug in the USB cable and power up the printer and see if it works (it probably won't) but I'm hoping it'll then cue itself looking for the 5200 series drivers which supposedly do work according to one post on MS forum, I quote:
"After reading all these posts I was both discouraged, but more determined than ever to get my X83 to run on Vista. I have to say the determination payed off! That's right...I just both scanned and printed 7 pages on my X83 running on Vista!!!! Here's what I did. I first installed the XP driver for X83 hoping I could dumb my laptop down to make it run on an XP version....no luck there, but when I did that, my laptop recognized the X83 as a Lexmark 5200 series which is also an all in one. I thought, well, if that's what it wants, that's what I will give it. If you go to the Lexmark website and look under downloads/drivers, there is a list that shows all compatible OS. The 5200 series is listed here with a Vista compatible driver. Once I downloaded it and went through the installation wizard....it worked LIKE A DREAM!!!! I hope this helps all of you as I also understood and felt your frustrations! Good luck!!!"
article source http://forums.microsoft.com/technet/showpost.aspx?postid=503767&siteid=17&sb=0&d=1&at=7&ft=11&tf=0&pageid=1
Lexmark 5200 series drivers http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
xp driver http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0 you'll have to type in a search for the driver enter X83 in the field, follow the steps...
Apr 21, 2008 | Lexmark X83 All-In-One InkJet Printer
Will not print
Go to print. Prinrt comand comes up just fine. Press ok and nothing. Document pending is all I get. Printer seems to be ready but goes into power save waiting for next comand,
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Accessories for Lexmark X83 All-In-One Inkjet printer
Lexmark software can usually be downloaded from the lexmark website.
Nov 13, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83
erform the following checks on the bi-directional communication:
1. Temporarily unplug the power cord and then plug it back into the wall outlet. If necessary, turn the printer back on. The printer should make a resetting sound.
2. Make sure that the print cartridge has been installed correctly and the cover snapped into place.
3. Also make sure that the printer is directly connected to the USB port (or parallel port, where applicable) on the PC.
4. An IEEE-1284 bi-directional parallel printer cable is required (not applicable for USB).
5. If there is another peripheral device connected, remove it and connect the printer directly.
6. If the problem persists, continue as instructed below.
To prevent the drvwppqt.vxd virtual device driver from being loaded:
Warning! Do not implement this solution if you have a tape backup device connected to a parallel (LPT) port on your computer.
1. Click Start, point to Find, and then click Files Or Folders.
2. In the Named box, type drvwppqt.vxd and then click Find Now.
3. Rename all instances of the file by changing the file name extension from .vxd to .old. This will prevent the driver from being loaded.
Oct 31, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 missing parts
You can download the drivers from Lexmark website. If it is just the power cord, you may be able to find one from another piece of equipment that will work. But, if you lost the "brick" for the power supply that would be harder to replace. A new printer would probably cost less than replacing the parts. You can get a new Lexmark All-In-One for $60-$99 dollars. The print quality on a new printer would be better, and the cartridges are less expensive.
Sep 19, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
