Question about E-Machines etower 400i PC Desktop
Setup cannot copy the file:p3.sys
I am installing windows 2003 and receiving the above problem
  • 916 Answers
This has to be a problem with your installation disc itself make sure it is not scratched. If it is a backup copy the files may have gotten corrupted. You will need to a get a new copy of the installation disc to be able to install.
Posted on Feb 09, 2009
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
My daughters Asus eee pc MK90H notebook says windows could not start because system 32 is missing or corrupt. It says to use the original CD Rom, which obviously we dont have. Help what do we do?
To restore a missing or corrupt ntfs.sys file you must have the Windows XP CD and follow the below steps.
Insert the Windows XP CD into the computer and restart the computer.
As the computer is starting make sure to press a key to boot from the CD.
In the Windows XP setup screen press the 'R' key to run the Windows Recovery Console.
If prompted enter the number of Windows installation you're repairing.
At the command prompt type the below command.
copy x:\i386\ntfs.sys c:\windows\system32\drivers
* In the above example you would replace x: with the letter of your CD-ROM drive. Many computers have the CD-ROM drive configured as the D: drive.
If ntfs.sys is still on the computer you'll be prompted if you wish to overwrite the file. If prompted, press the Y key for Yes to overwrite the file.
Once the file has been successfully copied remove the CD and reboot your computer.
Do NOT use an OEM "Recovery Disc". Only a valid Windows XP media will work or a disc from the OEM that says "Operating System" may sometimes work depending on how the manufacturer labeled the CD.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | ASUS Eee PC 1000HE Netbook
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
Mtp function problem
Samsung MTP function Problem Solution It really worked for me.
1.)first copy umdf.exe from "wmp11-windowsxp-x86-enu.exe" to your Desktop, two methods:
a)unpack wmp11-windowsxp-x86-enu.exe(ex:with TotalCommander->Alt+F9) and copy umdf.exe to your Desktop
b)run the wmp11-windowsxp-x86-enu.exe(if you run it will extract the %TEMP% folder)
Click Start -> Run -> %temp% [ENTER]
Press F3 and search for "umdf.exe"
Copy this file to your Desktop
Cancel the WMP11 Setup
2.)Rename the folowing files, just copy&paste into your Command Prompt:
rename C:\WINDOWS\system32\drivers\wudfrd.sys test_wudfrd.sys
rename C:\WINDOWS\system32\drivers\wudfpf.sys test_wudfpf.sys
rename C:\WINDOWS\system32\wudfhost.exe test_wudfhost.exe
rename C:\WINDOWS\system32\wudfsvc.dll test_wudfsvc.dll
rename C:\WINDOWS\system32\wudfx.dll test_wudfx.dll
rename C:\WINDOWS\system32\wudfplatform.dll test_wudfplatform.dll
rename C:\WINDOWS\system32\wudfcoinstaller.dll test_wudfcoinstaller.dll [ENTER]
3.) Now run the umdf.exe and re-install it. After it's finished connect your phone and your MTP problem is solved.
Oct 24, 2010 | Cell Phones
Cannot Copy the File P3.sys
Try to check your hard drive. Use a utility tool specially made for the manufacturer of your hard drive. Ex. Seagate Hard Drive = Seatools
Western Digital = Data Lifeguard.
Check for any errors or bad sectors on the hard drive
Sep 05, 2009 | E-Machines etower 400i PC Desktop
I am having trouble running setup on my desktop
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Istalling windows xp
Is this a genuine copy of windows?, if not just press Esc to skip the fille
Sep 10, 2008 | Computers & Internet
Windows installation issues
Either you have a defective CD, or a defective Hard Drive, or defective memory. Firstly is this a clean install? Try reformatting the drive and running chkdsk or a manufacturers disk utility. Then remove fingerprints and other marks from CD by wiping from the centre outwards. Let me know how you get on.
Apr 27, 2008 | HP Compaq dx2000 Microtower PC Desktop
E-Machines etower 400i PC Desktop Logo
2,188 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
