Question about Syntax LT27HV 27 in. LCD HDTV
My screen on my syntax turns pink after it warms up for 10-20 min
The picture is fine for about 20-30 min then the entire screen turns pink and it only goes away after i let it cool down then the same problem .
  • roughnf49 Feb 09, 2009
    can anyone help me with this problem or links i can go to for tec answers i am about ready to through it out the window!!!!!!!!
A "pink screen" is symptomatic of a weak CCFL (backlight). Flourescent lights 1st dim, then flicker, and finally die. There's not enough intensity for the other colors to get through the polarizer films. CCFLs are measured in millimeters (dia. x lng.) Try but only if you're a techie!
Posted on Feb 18, 2010
  • 273 Answers
It could either be a lcd control board or a main bd causing this problem
im not sure you can get either part as of now
Posted on Oct 29, 2009
it all depend how you want your Beef
• 120-130 °F (50-55 °C) Internal appearance very red; very moist with warm juices. Approximate cooking and resting time: 20-25 min./lb. plus 8-10 min. resting
• 130-140 °F (55-60 °C) Internal appearance lighter red; very moist with warm juices. Approximate cooking and resting time: 25-30 min./lb.. plus 8-10 min. resting
Medium (with a touch of pink):
• 140-150 °F (60-65 °C) Internal appearance pink red color; moist with clear pink juice. Approximate cooking and resting time: 30-35 min./lb. plus 8-10 min. resting
• 150-165 °F (65-75 °C) Internal appearance no pink or red, slightly moist with clear juices
taken from
Cooking Temperatures for Beef
Oct 30, 2016 | Cars & Trucks
Entire screen has a pink tint. Can change to blue with settings. Cannot change to natural with tint etc.
Check that all cables are intact and plugged in correctly.
Turn of the TV completely. There might be a manual button on the tv for this. As the last thing, remove the power cord from the power outlet in the wall or where it is placed. Wait 1 min. Then put it back in, swith it on and turn on the TV again.
If this doesn't help and you have tried replacing the cable that you get the picture from (VGA, DVI, Antenna etc.) then it is most likely broken.
Jul 06, 2014 | Sceptre X400BV-FHD 40 in. LCD TV
Freezing picture on portion of screen
The power source to the pixels is defective.
Feb 23, 2014 | Computers & Internet
Black vertical line
This seems to be a problem with some older panels. If you are prepared to tackle the problem yourself then try the following.
WARNING there are some very high voltages within the TV which can be LETHAL so the greatest of care should be taken.
With the back of the TV removed, use a hair dryer and apply warm air to all the ribbon cables in turn until you find the one which causes the fault to disappear. Now turn your attention to the faulty ribbon and remake the connections as necessary.
Dec 19, 2013 | Insignia Televison & Video
Syntax Olevia 30" LCD - blue screen, then black screen, sound is on
you have a broken inverter board. I have a LT30HV, and it had the same problem. The inverter board supplies power to the backlight. Swap it out with a good one, and you're back in business.
To test, take a bright flashlight and point it at the screen just an inch or so off the surface. If you can see your picture, then you have a blown inverter.
it may not be worth fixing it. Wait for a good sale on a new one. My inverter cost about 150, and it was a remanufactured part. Not as good as the original part as it flickers just a tad. I had to take the entire TV apart, with pieces literally everywhere. My cats loved it.
Oct 21, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
No Sound or Picture
Check the power supply module first.
Jan 10, 2008 | Syntax LT30HV 30 in. HD-Ready LCD...
No Signal after 30 Mins
Posted for a similar problem:
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Sep 22, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Syntax LT27HV 27 in. LCD HDTV Logo
138 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
