Question about Amana 3.2 cu. ft. Top-Load Washer
Spin cycle leaves clothes very wet
Varibly the spin cycle leaves the clothes very wet...not normal for the spin cycle. Belt slipping??
    Sergeant:
  • 250 Answers
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Feb 09, 2009
Why are clothes soaking wet?
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Aug 10, 2014 | Whirlpool Washing Machines
Ge wslp1100a0ww washer leaves clothes soaking wet, not spinning properly
You don't say whether agitation is normal. Improper spin can be slipping V belt (stretched or cracked), part #WH01X10081, or loss of transmission fluid. Is there oil on the ground under the washer (shouldn't be)? Let's start here. Motor, belt, and transmission are at the bottom of the washer.
Jun 04, 2014 | GE Spacemaker WSLP1100D Top Load Washer
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
My clothes are still very wet after the spin cycle, maybe it's the belt?
It very well coud be the belt. If it is worn or slipping, it will leave your clothes wet.
Mar 06, 2011 | Washing Machines
It spins during rinse cycle but the clothes don't spin dry. Still very wet, even after a second spin without any more water being added.
It may not be spinning fast enough. Is the agitator operating at normal speed?
Possible causes for slow spin are overloaded washer, slipping belt, bad bearings in the motor or clutch, or slipping clutch.
Another possibility is a problem with the pump, but I suppose you would also see some water left in the bottom of the machine in that case.
Dec 05, 2010 | Whirlpool LSQ8543J
Ca230 w. machine not spinning leaving clothe wet, no water in drm
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
Dec 06, 2017 | GE S8000E
Clothes still wet after final spin cycle
It sounds like you might have a broken belt or the belt just slipped off the pulley!
Jan 22, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
2,344 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
