Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
Lance lost nozzle off my durabuilt washer. need a new lance
  • Anonymous Mar 12, 2014
    cant undo rotating nozzle from lance
    Scholar:
  • 50 Answers
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Posted on Feb 09, 2009
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
How to clean out a power washer
This sounds like you need to bleed the system of air. If you take off the lance and then hold the trigger untill you have a steady jet flow and then once this is achieved put the lance back on.
It could also be that something is blocking the nozzle of the lance.
Apr 11, 2012 | Karcher Garden
I have a durabuilt model 1404 and i need a new gun and the adjustable nozzle
We have this gun / wand / nozzle available. Please call 800.257.8103 or visit our website at www.landanw.com for more information.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 10, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
Lost pressure
try this
dissconect hose and lance , and check for water flow through the machine , if theres none or just a trickle then you may have gunk in your inlet filter ( usually a small plastic gauze insert just where the water feed hose connects )
then start machine , check for high pressure flow ( you will see the difference )
its quite common for the nozzle on the lance to become blocked
if all this seems fine but the lance is vibrating then you have a blockage in one or more of your pump valves .
Nov 11, 2009 | Honda Pressure Washer PSI 3000
Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Jun 29, 2009 | Garden
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
718 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
