Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet ht...does not spin out?
Spin cycle is not working, just flips back and forth. thank you jmi
  • robert samples May 11, 2010
    how many clothes are in the washer when this happens
  • 20 Answers
Run it with no clothes, wait the entire cycle because it only spins fast at the end, dont overload the machine.
Posted on Feb 13, 2009
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
Mar 16, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a duet ht. Whenever I set it to do any wash program, it progresses perfectly until the 1:00 minuet mark. Then it just rocks back an forth forever. If I then switch it to "drain &...
The program must be detecting over sudsing. How much detergent are you using? Are you using HE?
If not then the motor will over amp, heatup, and, lock up. If soap is not the issue then you have objects between the tubs causing the problem. Duet sport service manual
Jul 16, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet HT has Knock in Spin cycle
well id be leary myself and honestly not at the machine but the tech(s) that are looking at it. i would put back in for another call request a different company if possible.Theres probably 7-8 authorized Whirlpool service Companies in my area alone. acn demand that the tech call the Technical assistance line if unsure of problem.I cant see telling a cust "normal noise don't worry about". these units spin very quietly.On a side note they were installed correctly??? strange to get 2 with came problem..
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
383 people viewed this question
Dan Webster
Dan Webster
Sal De
