Question about GE Spacemaker JVM1640SJ Microwave Oven
GE micro wave Spacemaker
Turn table does not work
    Problem Solver:
  • 17 Answers
The turntable is either plastic gear driven or uses a belt. either way, it's usually all non metallic due to the microwaves. you'll need to see if the motor that drives these are turning by removing the case. this can be EXTREMELY dangerous as the radiation from the cylstron tube. if it's a simple as a belt, the part can be replaced. good place to go is www.repairclinic.com
Be sure and rate me for this solution
Posted on Feb 09, 2009
GE micro wave oven turn table won't work Model LVM1750DM1BB, #SM900740B
first:check AC chord.,
2nd:check fuse,f fuse open check big capacitor.
3rd:check heating element if shorted replace it....hope it can help.
Sep 22, 2013 | GE Microwave Ovens
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
    If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
    Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
    Why would my microwave no longer heat or cook?
    micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
    Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Micro wave stopped heating. All other features
    Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
    Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
    YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
    Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
    My spacemaker GE 1440 do not heat it 2 years old
    Hi tony,
    The units magnetron(the device that generates the micro waves) is failed or failing, this can be DIY depending on how mechanically inclined you are.
    anaanymous
    Oct 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    228 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    D. E. Hev
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
