Question about Acer Aspire 3680 Laptop
Warning u must plug magicJack in usb
I plug in the magicjack however it shows warning u must plug magicjack in usb, tried it in many usb plug however it doesnt do anything else..
  • 6 more comments
  • hajerhec Apr 15, 2009
    each time i want to use my magicjack, it comes warning with red and said warning u must plug in usb
  • hajerhec May 11, 2010
    i have a same problem and i don't know how i fix it
    and there's not a phone number u can call and get help
  • wa2yyx Jul 26, 2014
    When you first take MJ out of the package you need to plug it directly into a USB port on your computer. This lets it update with the latest software and installs it into your MJ.
    After it updates you should take it out of the USB socket and use it with your router. It should then work okey. By the way about once every month you should power down your modem and router then power them up again. Ar if your experiencing any problems with MJ then you should do this as well.
    Add a CommentGood luck,
    Add a CommentMarty
  • Acer Master
  • 2,404 Answers
Courtesy of the MagicJack website, try these steps located here to resolve the problem:
http://www.magicjacksupport.com/warning-you-must-plug-magicjack-into-usb-t3208.html
Its the first message that is closest to the top of the page that gives you the instructions.
Posted on Feb 09, 2009
    Problem Solver:
  • 5 Answers
I found a helpful article if it says "warning you must plug magicjack USB"
http://www.infobarrel.com/MagicJack_USB_troubleshooting
Posted on May 04, 2009
  • 3 Answers
After reading the solutions, I had the best result by formatting the MagicJack drive then letting the software install again. This seemed to work best , but eventually the problem would come back. So I looked a little further and realized that my USB bus voltage / current output may not be sufficient or unstable to consistently drive the device. I recommend that a powered USB hub be installed on the computer, then plug the MagicJAck into thar hub. I bought a cheap USB powered hub at Wal-Mart and so far MagicJAck has ran more stable. Give it a try!!
Posted on Apr 28, 2009
I can call out on my Majic Jack Plus but cannot receive calls. The majic Jack is registered and set up on my modem.
This could be failure of the power adapter module.
Is your Magicjack plugged into the wall power thru a power adapter? Try bypassing the power adapter and plugging the magicjack directly into a USB port on your computer. If the magicjack work correctly now, then you have a bad power adapter module.
I had a similar problem. My Magicjack was plugged into a wall socket. First the dial tone became inconsistent, then I could no longer receive calls, then it died completely.
I plugged the MJ into a USB socket on my computer, and it then worked normally.
If you have a failing power adatper, it will continue to deteriorate, and it will eventually fail completely. The blue power on the magicjack will not come on when it is plugged into the power adapter, but it will illuminate when plugged into the USB socket on the computer.
Note: the computer must be on to power the magicjack thru the USB port.
Magicjack is aware of the problem and offers a replacement power adapter module. To contact them, go to www.magicjack.com and go to "support". They will ship you a new power module for about $5.50. Some people have reported that the replacement modules from Magicjack are no better than the originals and have had repeat failures.
Consider getting a power module from another source. There are lots of AC to USB power converter modules available on Ebay for only a few dollars. Search Ebay for "magicjack power adapter".
Oct 05, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
My phone doesn't ring. The call goes directly to my computer and I don't know someone is calling.
Is your Magicjack plugged into the wall power thru a power adapter? Try bypassing the power adapter and plugging the magicjack directly into a USB port on your computer. If the magicjack work correctly now, then you have a bad power module.
I had a similar problem. My Magicjack was plugged into a wall socket. First the dial tone became inconsistent, then I could no longer make calls out, then it died completely.
Oct 01, 2014 | magicJack pc to phone, free local & long...
I can hear perfectly the party I call or when they call me but they can never hear me clearly
This maybe due to "echo" n long distance calls.
magicJack works hard to ensure a clear connection.
If you experience an "echo" when using a magicJack on a computer:
  1. Go to "Menu" on the top right-hand corner on your magicJack softphone
  2. Click "Headset/Volume Control..."
  3. Lower the volume for both "Speaker" and "Microphone" to about 1/3 (one-third) of the maximum levels.
If that does not work:
  • Try plugging your magicJack into a different USB port.
  • Unplug your magicJack, restart your computer, and plug your magicJack back in.
  1. Unplug your magicJack, turn your modem and router ( if you have one) off and wait 3 minutes.
  2. Turn your modem and router back on and plug your magicJack back in.
If you experience an "echo" when using a magicJack connected to modem or router:
  1. Lower the volume on your telephone.
  2. Unplug your magicJack from the power source, wait 30 seconds, and plug it back.
Jul 20, 2014 | magicjack.com Computers & Internet
Not funtion
Check you have it plugged into your computers USB port.
Check you have an Internet connection.
If you have done this it should start up and show an magicjack icon on the screen.
If not talk to customer service on
International VoIP Phone Service Customer Care Support magicJack
Feb 06, 2014 | magicjack.com
My Majic Jack Plus is not working ,the light is not coming on.
,M MK,MVCOKJKVCJIIJCVXIJIHJVLLLFLMPFKKKKFHJUGDKKHDFSUHGHTCSDGFYFTYTASDFSD HFYVSDFYGVASD SDYYSDYTF ASAVYSJUUASTFSDISDJJDHSHYUSDYGBSDYGUJKSDFIHDFSHSDYCAS6FTBB BASDUGTTSDFYG7SDBB DFUSDGVGGSD7FUIYUASVBB SDUTASDYFSDTYASDFYXSUSDFGFODFGSDGASDFSDFUSD
Dec 14, 2013 | magicJack Two, 2 Magic Jack Plus Voip...
Warning message being displayed when magicjack is plugged
My Magic Jack was working fine. One day I got some viruses in my computer and I ran setup CD.After that magic jack is not working, it always display "Warning you must plug magic jack into usb".
I tried to chat with tech persons so many times and tried many methods but when they say "now unplug and plug in" , then magic jack home page opened on chating window (always) and stopped chating.
and still I'm getting same 'warning' message.
Oct 23, 2008 | Computers & Internet
Warning you must plug magicjack into usb
I was receiving "You must plug magic jack into usb" error
This is the fix that worked:
please download and Run the remover :
http://upgrades.talk4free.com/tools/mjRemover.exe
after you have done that , download the MS Fix http://go.microsoft.com/?linkid=9645377
then Run the UPGRADE http://upgrades.magicjack.com/upgrade/upgrade.exe
Oct 08, 2008 | Lands Phones
Magicjack phone is not working
i had unpluged and plug it back in and now it dont work
Oct 05, 2008 | Lands Phones
Acer Aspire 3680 Laptop Logo
1,099 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
