Question about Intertherm P3RC-042K Air Conditioner
Installing hard start capacitor
There are two wires on the capacitor and three wires on the run capacitor which are red,blue, yellow which do I connect to?
    Scholar:
  • 144 Answers
Hi, welcome to fixya. Color coding is not universal so we can't go strictly by that. You want to look at the top of the run capacitor and connect the two leads to the terminals marked C or common and the one marked comp. Be sure not to connect to the terminal marked F or fan. I hope this helped. Please don't forget to return and give me a fixya rating.
Posted on Feb 10, 2009
Table fan winding&connection daigram
  • I have a Bionaire brand table electric fan.
    • It has a 3 speed fan motor.
    • The electric motor is a BM-122 Decomin brand 3 speed motor.
      • There are 6 wires:
        • Red wire.
        • Black wire.
        • White wire.
        • Yellow wire.
        • Gray wire.
        • Blue wire.
          • The motor has a 4mu 250volt capacitor.
  • This fan has an oscillating grill with independent sync motor, and timer circuit.
  • Something was wrong with the solid state circuitry (everything worked but the motor!), but a quick test of the motor indicated it does work.
  • The motor uses a start and run capacitor.
  • I decided to change controls to a simple mechanical switch and fore go for now anything beyond 3 speeds.
  • The printed circuit board shows the following connections:
    • Black wire
    • Blue wire
    • Yellow wire
      • Are respective for the:
        • High fan motor speed
        • Medium fan motor speed
        • Low fan motor speed
  • I think the gray wire goes out to the oscillator motor.
    • The Red wire is marked as Line, for the power source.
  • All wires are in continuity with each other EXCEPT RED is not with any other wire. How to Verify Fan Motor Wiring Connections
    • Checking the Motor and Capacitor Connections
    • Double check your connections using the fan wiring diagrams.
    • You should see that there is a separate motor winding for high speed.
      • The concern is that there is a capacitor for the motor.
      • So I'm thinking that the motor may have to start with the slower speeds first.
      • and not start in the high speed because the motor or capacitor has not been designed for that type of operation.
Sep 29, 2016 | Dryers
What color wires goes to which connector on the run capacitor
hard to say as it varies from manufactures. their is normally only 1 wire on connector marked HERM ( MOST LIKELY THE BLUE) AND THE OTHERS TO THE "C" for common. Does capacitor have 2 or 3 posts for connections ?
Apr 29, 2016 | Heating & Cooling
I disconnected the capacitor on my Westinghouse HVAC unit. I took pics to help me put the replacement on and my pics don't show exactly which prongs the wires hook to. I know the blue wire goes on...
You are talking about a three post capacitor. One post may have 2 or 3 prongs, but it is still the same post and it doesn't matter which prong you put it on as long as your are on the right post. I am going to try and send you a video of a three post capacitor hoping it will help you. One post is for the "fan" whiich, by what you are telling me is the blue wire. "fan" will be marked right on the top of the capacitor next to the post. Sounds like the Red is "herm" which is a compressor wire. Orange and Yellow are the "C" wires. One wire will go to the fan and one will go to the compressor.
Again,, It doesn't matter which spade or "prong" you are putting it on as long as you are on the herm, c or fan post. hope this helps.
Jun 23, 2011 | Heating & Cooling
I am installing a Mars 1/3 hp fan motor. It has a black wire,red wire, blue wire, yellow wire and (2) brown wire that go to a capacitor. May Furnace has Black power wire, red wire (speed) and white common....
Hello, Typically your common wire will be white, high speed- black, medium speed- yellow, medium low-blue, red- low. The motor could still run for a short time if it was wired wrong but will either trip a breaker or go off on it;s overload when it's gets hot.
Feb 26, 2011 | Heating & Cooling
How do I wire a new condensor fan motor to the new capacitor? The old capacitor is longer and it has 3 terminals. the new capacitor is much smaller and oval. It has 2 terminals. the fan motor has 3 wires,...
Before attempting any of these recommendations, First disconnect all the power sources and check your wiring diagrams on the motor and condensing unit.
On the old capacitor if you look on the top near each of the three terminals. Are they marked, fan - C - herm? If they are that is a dual capacitor and that needs to stay because that is also your compressor capacitor.
The Red wire from the conductor is Run and it's connected to C on the old capacitor.
Follow the Yellow wire and see if it goes to the S or start terminal on the compressor, if it does then that is the Start wire for your compressor and it connects to herm on the capacitor.
For the fan motor a lot of times the wiring connections are printed on the motor label.
Check the label, Purple should be run and connect to C on the old capacitor.
Black should be Common and it connects to the opposite side of the contactor as the Red wire. If the Red wire connects to T1 then the Black wire connects to T2.
The Brown wire shoud be the start wire on the fan motor and it connects to the Fan terminal on the old capacitor.
Now if you want to use the new fan capacitor. Take the Purple wire from the motor and look for any marks (red paint or a dash) on or beside the terminals on the new capacitor. If there is an identifying mark then connect the Purple wire to that terminal, if no marks you can connect it to either terminal. Then you need a jumper wire from C on the old capacitor to the purple side of the new capacitor. Then take the brown wire and connect it to opposite terminal of the new capacitor.
Apr 05, 2010 | Heating & Cooling
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
I am replacing the a/c blower motor and capacitor. The old motor has 1 brown wire to the capacitor, 1 yellow wire to the capacitor (the yellow then loops from the capacitor over to the wiring panel), 1...
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Apr 27, 2009 | Heating & Cooling
Connecting a motor starting capacitor
New Capacitor
herm start on the compressor
fan start on fan motor
c run or power to both compressor and fan
Apr 25, 2009 | Kenmore 75085 Air Conditioner
I purchased a motor from a surplus company and it was supplied with a capacitor, but no wiring diagram. It is a 115 vac motor and has 3 wires (red, black and yellow) How would I find out which wires is for...
If you know the motor brand you could call a local motor repair shop and they are usually glad to help. A lot of motors are usually color coded with red wire low speed and black as high speed and on 230 volt motors Red and Black wires are usually L1 and L2 so I'm unsure as to which wires go where and what the voltage is. If you know for sure this is a permanent split capacitor motor then you should be able to ohm it out. start and run would be the total sum of Common to run and common to start.
Do you have an Ohmmeter and do you know how to use one?
For instance by ohming it out if (yellow to red was 5.0 ohms start to run) and (black to red was 1.8 ohms common to run) and (black to yellow was 3.2 ohms common to start), that would mean (yellow to the start side of capacitor) and (red to the run or other side of capacitor and jumper from red to L2) (some capacitors you can wire any way no identified terminal) and (black to L2 or common).
Apr 11, 2009 | Dometic Rooftop RV Air Conditioner
U-Line combo 75 not getting cold
hi there,
i have some procedure in troubleshooting a ref., as follows:
1. check if the compressor will run when you plug the ref in the outlet/power.
a. if the compressor run and it will not produce the cold or heat. then the problem is, the system of your ref. has a leak. it lost all the freon charge into the system. find a near service center in your area.
b. if the compressor run and it stop. unplug your ref. from power.
  • check the capacitor if it is ok, using a multi tester. by determining a good capacitor in resistance test at 100 kilo ohms or 10 kilo ohms the pointer will deflect to right and it will slowly going to left or a higher rating. bad ca[pacitor pointer steady in zero position or infinite.
  • but if the capacitor is ok then some trouble in mechanical parts inside the compressor. specially when you turn on your ref. you feel some surge power from the case of the ref. find a near service center in your area. if you need to replace the compressor and some parts of it.
c. if the compressor will not run, unplug your ref from power and then check the follow:
  • check the compressor resistance by using a multi tester, open the terminal box of the compressor. have some checklist in the terminal setting that has a letter symbol R (running) connected to what color of wire, same also with S (start) and C (capacitor) check in its terminal resistance.
Nov 29, 2008 | U-Line Refrigerator Ice Maker
Intertherm P3RC-042K Air Conditioner Logo
1,294 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
