Question about Hitachi 53UDX10B 53" Rear Projection Television
Double images and not sure what to call it
I have some pictures that I took of the tv with the problem but I am not sure if it is a confergance problem or not. Please let me know if there is any place I can place the picture for viewing.
  • brivero Feb 24, 2009
    Thank you for your response. Here is the link for the pictures:
    Any help on this would be great. Thanks again.
    I will try that first and if not I am going to try and fix this myself. It has become the second TV in the house, which I will use primarily for video games.
    Are there kits that I can buy for replacment parts?
    Thanks again
  • 15,935 Answers
Photobucket has free webstorage for photos. then you can place a link here.
Definately sounds like a convergence problem. Have you checked your manual on setting it?
CLICK HERE to view your manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 09, 2009
  • blueextc3221
    blueextc3221 Feb 24, 2009
    WOW - that is definately a convergence problem!!! lol
    Use the link to the manual i sent to try and adjust manually.
    If not, a service call will be required.
  • blueextc3221
    blueextc3221 Feb 25, 2009
    No, sorry no "kits".
    Repairing logical circuitboards takes many years to master.
    If you open up the TV, and can see ovious signs of damage - chances are the "visual" damage is not all that has ocurred.
    FET Relays all look good to the naked eye, but can only be tested with specialized equipment - unless you de-solder it from the board to test it.
    Im confident the convergence set will solve your problem - the 3 lamps are not aligned. The problem being - is it even POSSIBLE to set because of different board related problems?
    Only you will be able to troubleshoot, and determine if the repair is beyond your skillset.
    I would guesstimate - depending on your location... That if the convergence board were the culprit - that a local tech in your area might be able to have it repaired for under $75.
    Thanks again for using Fixya and the -helpful- rating you gave my answer.
Double picture
what is this double image or ringing picture??? if double image you have to check the orientation of your antenna, if it is ringing picture you have to adjust your frequency control by putting it to 15,750khz something don't forget to use your oscilloscope and your frequency counter..
Sep 10, 2013 | Samsung UN55B7100 TV
There is double imaging on my samsung tv, i replaced the tcon board and it still has the double image.
does it go away when the set warms up? or if you tap the set? Sounds like a possible defective LCD panel tab. Samsungs and Sony's are known for this.
Dec 04, 2012 | Samsung LN40A650A LCD TV
My zenith sentry tv has a double image on the words that come on screen. The people are clear but all wording has double images
Double images are technically called Ghosts, occures due to the setting and direction on the antena. You have to reorient your antena, in such a way that Ghosts disappeares from your screen. The reson for this fault is not with the TV, as it gets a direct transmission signal, and a reflected signal of the same, reflected from near or far objects, like tall buldings, hills and so on. The signals, the orginal and the reflected, will be processed by the TVs internal ciiruit, and the first will appear as strong picture, followed by the second, a weak picture, will be seemed as an image of the first one, just on the right side [view point] of your TV.
You just adjust the position and height of your antena, looking the picture, where there is minimum Ghost level is. No other repair should be done to your TV, as it is perfect, and you just give it only direct signal path. OK.
Nov 22, 2010 | ZenithZ2541S 25" TV
Double screen image
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
Double images
you will need to have the tv re converged to make the picture right call a repairman
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Double picture at star up
if you have cable telivison try unpluging the cable from wall and tv the replugging it. make sure the connections are secure and also make sure the cable is plugged in straight. or your cable might be bad.
Jan 09, 2009 | Sony KDL-40XBR4 40 in. LCD HDTV
Blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Apr 16, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Double picture
Can you give more details? What do you mean by Double picture? Do you have 2 pictures side by side or One on top of another? Or is it like a shadow behind the main Image? If it is a shadow (Ghosting), check your Antenna - connection, direction, etc.
Sep 05, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
117 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
