Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Uneven Doors for KitchenAid Refrigerator
Our new KitchenAid side-by-side freezer door is higher than the refrigerator door by 3/8"+ at the center, but can't get them level. The service technician would like to use sealer gum sticking in gasket to increase the thickness of refrigerator door ( 23" x 72"). Will this remedy cause gasket to be easily torn apart because of adding the weight of sealer gum (4-1/8" x 1" x 5/8" each piece)? Also, air leaking might be caused after continuous using... Thanks KitchenAid Model: KSSC42FTS03
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
  • 1122 Answers
SOURCE: Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Posted on Oct 14, 2008
  • 1462 Answers
SOURCE: side by side refrigerator model # 51562103 center wall - very hot
if fridge and freezer temps are normal, what on earth is your problem?
Posted on Nov 14, 2008
SOURCE: Warm refrigerator compartment
We had similar problem. Found the interior lights of refrig. were not turning off. Found out this was a recall problem and was fixed by sears for free.
Posted on Aug 09, 2009
  • 15935 Answers
SOURCE: kenmore elite side by side freezer door higher
Check the lower mount bushing. These are nylon and wear/break easily.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door '
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    I have a KSSC48QMSO1, The center panel, that divides the freezer from the refrigerator is hot to the touch at the top end and only where the side doors close together. Also the refrigerator is not holding...
    could be a problem with a dirty condenser or your condenser fan may be no good. That will cause the center panel to be hot and will prevent the refrigerator from cooling properly. Is the sides of the fridge hot to the touch as well?
    Mar 18, 2011 | KitchenAid KSSC48QMS Side by Side...
    Doors are not even across the top
    Is this a new problem? Or have the doors always been uneven?
    Is your floor level? A tilting floor can make an appliance look uneven. Even if you assume your floor is level, it might be worth checking. Floors can change over time.
    Is one door level but the other out of plumb? If so, the problem could be the hinges on the uneven door. This could be caused, for example, by overloading the door trays. One of the hinges could have become bent or damaged. If this is the case, it should be replaced. Check all the hinges carefully for signs of damage or wear. If both doors are out of plumb, it's possible that both doors have damaged hinges.
    Another question is: just how uneven are they? Are they uneven by less than 3 millimetres? Or more than 2 centimetres? Obviously the bigger the unevenness the more likely you will need to get it fixed. But if it's tiny, it might be just cosmetic and unless it really bothers you it could be left alone.
    I hope that helps a bit. Good luck!
    Oct 09, 2010 | KitchenAid (KSRD22FKST) Side by Side...
    Panel between doors is hot
    Many models of refrigerators have a heating element around where the gasket seals to the fridge. This is to prevent ice buildup around the doors that would prevent the doors from closing all the way.
    If you haven't noticed any other problems with the cooling of your unit, you're refrigerator is running exactly the way it was designed.
    Mar 26, 2010 | KitchenAid Superba KSRG25FK Side by Side...
    Fridge door is lower then freezer door
    The #1 cause for this problem: The floor beneath the fridge is uneven, causing the refrigerator "box" to be out of square. Adjust the levelers on the fridge bottom to compensate for the uneven floor. That should do it.
    May 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
    Warm refrigerator
    Check the freezer fan.
    Is it running?
    If not, replace fan motor.
    Check the damper doors in the fresh food side.
    Does air flow through?
    Mar 08, 2009 | KitchenAid Refrigerators
    How do you level the kitechenaid side by side
    Hope this helps solve your problem, Let me know. Thanks, Sea Breeze
    This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
    Feb 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
    Can the doors of both the refrigerator and freezer be reversed to open from the other side?
    yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
    Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
    Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
    91 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
