Question about Brother IntelliFAX 4100 Laser Fax
Can I use as phone/answering machine and fax
I would like to use this machine to be a phone/answering machine ie 1 to leave a message 2 for fax
  • 215 Answers
No, this machine does not have a message center. the only way is to hook an actual answering machine up to the "ext" jack on your fax. set fax to answer on 1-2 rings, and set your answering machine to answer on at least 4 rings, and set your fax receive mode to "tad" which means telephone answering device.
razors
Posted on Mar 30, 2009
How to you hook up an answering machine to a Samsung all in one printer
there should be two phone jacks in the back one says phone plug your answering machine into it
Aug 28, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Have a new all in one printer (print, fax, scan and copy) feature
Here's where a Panasonic TA-824 would work great. At a street price of about $200, you can control your 3 lines and up to 8 extensions, one of them being your fax machine that would have access from both lines, and an answering machine that could take messages.
Some of the fax machines can detect a fax tone on a phone line, so you could have the answering machine answer the call and you tell them to press send (or it listens for a CNG tone, but the fax machine is limited to only one line.
Carl
Apr 01, 2009 | Panasonic KX-TG2740 Cordless Phone
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Canon imageCLASS® MF4150 All-In-One picks up all calls on our second line.
I got in touch with the manufacturer tech support and found there was no way around it. Thanks for considering my issue though :)
Sep 12, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
Fax & Phone sharing the same line
I am not really familiar with your machine, but have worked on faxes for 20 years. Most models are fax, fax/tel, and tel, meaning it is either or, or a combination. The function you seek was on many models with a built in answering machine. As the machine answered, you said in your message to press start now, or leave a message.
I would say, use your *9* solution with phone while you are there, but switch it to fax mode when you leave. Any regular call coming in at that time will not get answered anyway, but faxes would automatically be received. I know it is an extra step, but that would work.
Mar 08, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP 7410 fax tone when answering machine starts
you can only have it set to fax or phone at a time; the computer does not know if it is a fax or phone call. Therefore if you are running your fax software it will treat all calls as a fax. You really need two phone lines, one for the fax and one for the phone.
Dec 28, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Can I use this fax on a telephone line together with a GE 2.4 GHz Cordless Telephone (Model 27992B)? Will it be possible to recive messages and faxes when no one is at home? Remark: The answering machine...
sure u can: Installation with an answering machine and/or extension telephone: 1. Remove the seal covering the TEL. SET jack on the rear of the fax. Connect an extension telephone or answering machine to the TEL. SET jack. 2. If desired, connect an extension phone to the answering machine. from the user Fax guide: If desired,you can also connect an answering machine or an extension telephone to your fax. ¨ Connecting an answering machine to the fax will allow you to receive both voice and fax messages on the same line while you are out. For details on using this feature, see Chapter 7. (Note: Do not connect an answering machine to your fax if you will be using the distinctive ring feature described in Chapter 2.) ¨ You can connect an extension phone to the fax to make and receive calls like any other extension phone on your line.
Oct 09, 2005 | Sharp UX 510 Plain Paper Thermal transfer...
Brother IntelliFAX 4100 Laser Fax Logo
146 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
