Question about Hotpoint WD62 Front Load Washer / Dryer
WD62 DOES NOT CYCLE THROUGH ITS PROGRAMME
Hi i`m having problems with my hotpoint wd62, it is not cycling through its programme, i`ve changed the brushes on the motor and that turns ok. Any ideas?
  • 77 Answers
Hi, this model is notorious for programme faults and i would suggest you change the controller, hope this helps
Posted on Feb 09, 2009
Se opreste motorul in mers cred ca sunt periile de vina. De unde iau si *** se schimba
Posted on Mar 30, 2009
Hotpoint wd62 had to bang door to make it work, now stopped altogether could it be knackered interlock.
In a word 'yes' and glad you know our technical jargon!
It calls for a call- to your local service engineer unless, that is, you can change it?
Good luck,
John C
Feb 27, 2011 | Hotpoint WD62 Front Load Washer / Dryer
Hi I have a hotpoint WD62 washer dryer. when I'm using the dryer the clothes still come out wet like the steam is not going out of the machine. Any tips on what to check for? Could something be...
I had the problem. I replaced the water inlet valve, and that fixed it. It seems no cold water was coming in on the drying cycle to condense the steam.
Sep 24, 2010 | Hotpoint WD62 Front Load Washer / Dryer
Aquarius wd62 front drawer leaks
I had this problem and solved it by just leaving the draw sticking out a little bit! Now there are no leaks!
Feb 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 leaks heavily during spin cycle
hiya m8 check the door seal first you'll need to pull the seal slightly out to see under the flappy part they usually go there this will be the most likest leak u don't have to undue anything to do any of this and when u find the hole it will only be around £15 to get a new door seal u might have to run your fingers around under the flap to find it aswell m8 let me know if it is and ill tell u how to replace it m8
May 25, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 W/D. Works OK empty but bangs when full
Sure easily. Plug off the wall, open up behind to check if any springs have come off, check the shockabsorber, bolts.
Feb 11, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint W/D valve problem
yes change inserts around leave top off test and watch. red is for hot water black for cold
Nov 20, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Front Load Washer / Dryer Logo
203 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
