Question about Kenmore 72802 Gas Dryer
Belt off of kenmore model 87870100. How do I put belt back on?
The belt and pully looks like they have come off the motor. I am not sure how the system is supposed to look. Any idea?
  • jhowell14 Feb 09, 2009
    Great help. Thanks so much
  • 15,935 Answers
CLICK HERE for a rather good tutorial.
Visual Pic..
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 09, 2009
I have a kenmore gas dryer does not rotate believe the delt is the proublem. model #87870100
note Kenmore/Whirlpool same belt configuration:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to open dryer:
http://www.applianceaid.com/wpdryer_how-to.html
Mar 19, 2011 | Kenmore Dryers
The belt for the dryer is not in place and the dryer is not longer spinning. how would i fix that? There is also a piece with a wheel on it that i cannot figure out where it goes but looks as though it is...
Look up "Tension Pully & Belt Diagram" on internet for your dryer on google or Dogpile. You should be able to find how to
put the Tension Pully back where it belongs & how to thread the belt through it and back on to the motor drive shaft. Check different sites for the right picture for your dryer. Here's a picture to get you started. Good luck,
Sep 13, 2010 | Kenmore 500 6952 Dryer
How do you rehook the belt up for the drum
tricky but belt around drum then pully tensioner at bottom of dryer the belt feeds through pully then onto motor gotta move pully while putting belt on motor take s some practice kinda hard to expain
Aug 19, 2010 | Kenmore 63942 Dryer
Cant install my belt back on my idler pully on my kenmore 80 series dryer . the idler pully i have is a piece of metal below but it does not open up so the belt will go through. i am missing something but...
Howdy: Check for the bolts that hold the pully on. Loosen the bolts and the pully should stat to open. You may have to put on the belt then install the pully. Look close at it. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
Cannot put the drum belt on
make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
Oct 14, 2009 | Kenmore 74602 Gas Dryer
Belt came off, don't know how to put belt back on
The platter should lift off and allow you to see the motor, drive pully's, and the belt. You should be able to put the belt back on the platter pully and then around the motor pully and the just align the platter back up with the spindle and gently lower it back into place. If the platter won't just pick right up off the spindle, look for three screws that hold it down to a triangular shaped support underneath. When you remove those screws, the platter should lift right off and allow you to see the drive pully and motor and belt. Good luck, and be gentle.
Sep 28, 2009 | Audio Players & Recorders
KENMORE DRYER MOD# LEQ9858LWO WILL NOT TURN BUT HEATS
If you hear a humming, then it is probably a broken or slipped belt from the motor to the drum. There is usually a pully on the shaft of the motor, a tensioner pully on a spring, and a groove on the back of the drum that the belt rides in. If this belt breaks or comes off track, the motor will still spin but the drum won't.
You will probably need to take the front or back off of the dryer (varies by model) to expose a view of the belt, and once you do this, it will be easier to see if the motor is turning or the belt has broken or slipped.
If the belt has slipped, be sure to inspect it for wear, and replace it if worn. Otherwise, it will slip again and you'll have to repeat the process.
Jun 10, 2009 | Whirlpool LEQ9858L Electric Dryer
Tention pulley or so i think
it goes in front of the motor,you'll see the slots in the cabinet under the motor,both side of the belt go under the pully and onto the motor pully-mike
Dec 14, 2008 | Kenmore 62602 Electric Dryer
Can't get drum belt on Kenmore dryer
Generally belt comes around drum then around pulley tensioner and then back to motor pulley in a zigzag fashion
May 06, 2017 | Dryers
Replaced idle pulley but drum wont spin when clothes are in it
Ok, when you removed the front cover to gain access to the idler pully, did you make sure that the drum didnt slip off one of the two roller wheels in the bottom rear of the dryer. If you get one of those roller wheels jammed and not in the track right, they will jam up. Look down at the bottom, grab the rollers, and pull them forward to be sure they are in the groove of the drum. Also, are you sure you relooped the belt correctly back around the idler pully? The best way to loop the belt is to place the idler pully in the correct position, then drop the belt down in front of it, loop the belt under the idler pully, push it back to tension everything, then take the loop and go over the motor pully (should be pretty tight). See if one of those solutions will help. Also be sure that you are properly getting the drum in the right position over the front seal (front should go on pretty easily, if not, reach your hand in the door, and lift up on the drum to center). Thanks and good luck!!!!
Jan 25, 2008 | Dryers
Kenmore 72802 Gas Dryer Logo
647 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
