Question about Pioneer DEH-P8600MP CD Player
Ribbon cable broken and now cannot open the face plate
Is there a manual way to open the face plate since the ribbon cable is broken. I have ordered the ribbon cable but can't get the faceplate open to replace it.
Also need to see if there is a ribbon puller/insertion tool that I can buy
  • koufax653905 Mar 24, 2009
    I have had the same problem for quite a while now. It just starts working after a little time. Sometimes the next day sometimes a few hours i love the deck and how it sounds but this is a bad problem.
    Problem Solver:
  • 7 Answers
The top of the deck case will pop off with a small flat screwdriver, inside you can see the cd mechanism and there is a larger white gear on the right side you can manually turn the gear which slides the face down....
Posted on Oct 30, 2012
  • 3 Answers
You need to take the unit apart to fix the cable since the other end of it plugs into the board inside, it's pretty easy to take apart though. Good luck!
Posted on May 13, 2009
Kenwood kdc-v7017 wont turn on, fuse is good
I tested the cable from the face plate to the pcm with a ohm meter and fond that there were a few broken wires in the ribbon cable so i found a downloadable service manual got the part numbers for the ribbon cable and the recptical that the faceplate contacts and ordered them from the kenwood parts web site
Jan 02, 2009 | Kenwood KDC-V7017 CD Player
Freezes while i press open
first check all of your power and ground connections and be sure your battery is good then try the small reset button on the front face. if that does not work you may need a new flexible ribbon cable that you can find on ebay cheap.
Nov 25, 2008 | Pioneer DEH-P9600MP CD Player
Replacing the facepale
that hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Sep 06, 2008 | Kenwood KDC-716S CD Player
Deh-p9800bt My screen is gone
I opened the radio and found that the wired ribbon that connect the front display plug to the inside main electronic board was cutted on the place that the ribbon bends when the face plate move in and out to take off the display or put a CD.(It sees like after years opening and closing ribbon makes an edge and break). I called Crutchfield and they brought this phone # for Pioneer replacement parts, Tel. 1-800-228-7221. I called and ordered the part (P/N:XNP7026, FACEPLATE RIBBON CABLE - $24.95) and I installed it, the decks is working perfect! If you have electronic working experience will be easy, if not, buy the part and bring it to an electronic shop. The front connector plug has to be reused. This cable is used on other models like : DEHP6800MP, DEHP7800MP, DEHP780MP, DEHP9800BT, and the DEH980BT. Hope that this help!
Jose Carrasquillo- Puerto Rico
Mar 19, 2008 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Power
I have a vrx755vd need part # for the face plate power ribbon
Oct 25, 2007 | Clarion VRX745VD Car DVD Player
Mechanical Face Plate Assembly
I dont have a manual but you might be able to download a service manual from the following website , I hope its helpful since some parts may not be serviceable on that face plate......... http://www.user-manuals.com/service-manual-KENWOOD-KDC716S.html
Mar 31, 2007 | Kenwood KDC-716S CD Player
Flip Down faceplate is stuck.
I have the same problem, and all my problem was is that one of the wheels were out of place. You can see these white gears at the bottom left and right. Just stick something in there and push it back in place. It should just snap back in.
Mar 16, 2007 | Dual XD-7500 CD Player
Face Plate
If this is a "flip face" type of display then you may have a broken lead in the ribbon cable that connects to the main board from the flip face. This is a very common problem. You'll need to replace that ribbon cable.
Mar 08, 2007 | Alpine CDA-7940
Pioneer DEH-P8600MP CD Player Logo
534 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
