Question about Insignia Digital-to-Analog Converter for Analog TVs
Insignia box has limited channels.
I bought an Insignia converter box, connected it thinking I should receive the same channels as with the antenna alone, only better reception. Surprise- I only get 4 channels. I should be receiving NBC based on info on the internet. After doing some research, a web-site informed me that with digital it is either all or nothing, unlike my antenna reception which is fair to good. This seems like a racket to force you into cable. Any comments or suggestions?
  • localeenda Feb 09, 2009
    Thank you. I will see how it is after conversion and see if there is a need for a new antenna or not.
  • 4,234 Answers
Many stations are not at full power for their digital broadcasts since they are broadcasting on analog as well. The signal srength should increase after the changeover. In the meantime, placing the antenna at the highest point will help. Also, changing the antenna to one designed for digital reception will help.
Dan
Posted on Feb 09, 2009
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
Do the new Insignia TV models need a converter or are they already digital ready?
the are digital ready with a qam tuner. what this means that you can either connect a cable line directly to the back and receive channels or connect a digital antenna and receive channels as well.
May 04, 2010 | Insignia Digital-to-Analog Converter for...
My Insignia Converter boxes - 7-19-09
Switch to a powered DTV antenna.
Your analog antenna may be too far out of range to effectively pick up signal.
Thanks for using FixYa!!
Jul 19, 2009 | Insignia Digital-to-Analog Converter for...
With converter box only receive 2-3 channel
They have powered antennas that give you more stations. I added a HD antenna I bought off ebay for 19 dollars and I get 10 stations. Please give me good rating It means a lot to me.
Jul 05, 2009 | Insignia Digital-to-Analog Converter for...
No Signal
Make sure you have a good connection from the antenna to the converter box. Set your TV to channel 3 or 4.
The converter won't improve reception in any way, and it's possible you might need to relocate your antenna or get an exterior antenna hooked up to improve the signal strength.
If you have enough antenna cable, and you're only using rabbit ears, hang them out the window or up on a curtain rod and see if that improves things.
Some people have good luck with the new digital style set-top antennas. I think you'll have best luck, though, with an old roof-top antenna that's set up to feed your converter.
Best of luck to you!
Apr 10, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Picture not clear when playing a recorded program from dvd
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
Jan 02, 2009 | Insignia Digital-to-Analog Converter for...
Lost the Welcome/Installation Menu
http://www.ezdigitaltv.com/support-files/ns_dxa1_manual.pdf
All you have to do is use the auto tuning function. Your remote control has a menu button, you can get to the feature via the on-screen menu.
If you press the menu button while the box is on and you see no menu, change your television's input to match what the box's output is.
Nov 23, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
Signal issues with my Insignia DTV converter box
As far as the antenna goes..NO. It is still an RF signal. The antenna just needs to be good for the frequency range of the stations you are receiving. The station numbers and frequency don't necessarily match like they use to. They are all over the place now.
Jun 21, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
141 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
