Question about Ricoh AficioSP 5100N Laser Printer
Open heat error
Came in this morning and saw "Open Heat Error" cycle power message on my sp 5100n Ricoh.
Any direction would be much appreicated
  • 2,404 Answers
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Posted on Feb 09, 2009
  • 679 Answers
"Open Heat Error" Means --- You need to make sure the voltage of the fuser is compatible with your printer.
Please rate the solution.
Thanks for using FixYa.
  • 1,602 Answers
GO ONLINE AND TYPE THE FOLLOWING
RICOH AFICIO?SP5100N LASER PRINTER ERROR OPEN HEAT ERROR.
OR
RICOH SP5100 PRINTER OPEN HEAT ERROR
OR
WWW.RICOH.COM/LASERPRINTERS
ROD
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
What is sc 565 on a sp c820
SC565
*Heat lamp consecutive on error
- Broken main fuser connection
- Check HR thermistors
- Heat roller lamp defective
- Power Supply defective
May 10, 2014 | Ricoh Aficio SP C820DN Laser Printer
I have a ricoh spc820dn printer and got error message SC553 any ideas how to clear?
Hi, I'd be glad to help you.
SC 553: Pressure roller fusing lamp over heat
The detected pressure roller temperature stays at 200°C or more for five seconds.
It could be:
• Defective PSU (power supply unit)
• Defective BCU (The BCU generates the FGATE signal based on the registration sensor ON timing).
Last time I had this error (over a year ago) on this model, it was the PSU.
Best of Luck
Dec 05, 2010 | Ricoh Aficio SP C820DN Laser Printer
Open heat error
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Nov 22, 2010 | Ricoh SP C220N Aficio Laser Printer
Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Apr 20, 2009 | Ricoh Aficio SP C210 Laser Printer
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Aficio Ricoh 350e - Warm up error (fuser)
Hi first you have to check the fusing unit and all give you how to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres okouble-
shooting
SC542: Fusing temperature warming-up error
-Definition- [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
- Possible causes -·
Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
if the proplem not solved contact me ill give you more detales . thanks
May 22, 2008 | Ricoh Aficio 450 Copier
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
Ricoh AficioSP 5100N Laser Printer Logo
2,719 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
