Question about Philips Magnavox 55P9271 55" Rear Projection Television
The color in my TV seems to be going out.
First it was all red screen now it looks almost as if were a black & white TV. I just got a new TV and was wondering if getting my old one fixed is worth the trouble?
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
77ea520.jThe color in my TV seems to be going out. - f0900cb.jpgh_mi
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are The color in my TV seems to be going out. - 2c07611.pnguld be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. YoThe color in my TV seems to be going out. - 578ba6c.jpgsee halos around images.
Picture of a set that needs the fluid changedThe color in my TV seems to be going out. - 65af323.jpgr />
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Posted on Feb 12, 2009
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
I have a sony kp-53n77 rear projection tv i cleaned the lenses but i still have alittle to much red how can i clean up the color
Older projection set:
Not knowing exactly what it looks like I suggest two things: first in the menu look for convergence to see if it is off adjustment wise--it can be adjusted in customer mode to see if that helps.
Also either turn color all the way off (Black and white) to see what color the screen is with no color--if somewhat red you will need to turn the red screen control down--I can tell you where and how.
If screen is too red, red will be the prominent background color with color off or on.
Another easy way to LOOK is go to an unused video input---should only see "Input 1" for example in green and rest of screen should be black and not red to any degree.
Let me know with a comment here what you find.
May 02, 2012 | Sony KP-53N77 TV
Philips hd tv monitor 51pp9303h/17 dp TV 345 347he10839 TV receiver 3135020592 my screen is red and I tried to adjust the color nothing happen it still red can I fix myself
The model indicated is a older rear projection set.
If you go to a program that is black and white and turn the color off the screen should be something close to black and white.
There is a way to adjust the red screen down but it takes two people.
If you want to know how and what is involved let me know.
Jan 17, 2012 | Philips Televison & Video
My color seems to be more green than should be and I have tried to reset the color with no help
You have a focus/screen control box Find it and adjust the R/G/B screen drives When you first start Go to Menu turn Color off then with a mirror adjust the picture as close as you can to a black and white picture R/G/B screen drives, the little control box you are looking for will have 3 controls on top for focus and 3 controls under them for screen drives to each tube red,green,blue after you have adjusted to a black and white picture then go back and turn color on.
Nov 30, 2009 | Akai PT4298HD Rear Projection Television
A/V in black and white
good day,
what video device do you plug in to your TV screen, DVD player/VCR or game console?
If you still have the owners manual of your TV screen, look for instruction regarding Color system or video system. this menu will allow you to change color sytem from PAL to NTSC or AUTO system.
most likely the reason why you have a black and white color from vidoe input is because of system color compatibilty from your input device to your screen.
Or if your using a dvd player, you can also try accessing the "setup" button and look for video setting. from the video setting there will be selection to choose from: PAL , NTSC, AUTO . always select "auto"
so that the color system of your DVD player can change from PAL to NTSC deffending on your TV screen system setup.
Feb 01, 2009 | Sanyo Over-the-Ear Sleek Boom Microphone...
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Black and white picture
Try going into player's menu, and set video out or TV type to NTSC.
It might have switched to PAL, or disc is PAL and player is set to any.
Dec 13, 2007 | Cyberhome CH-DVD 300 DVD Player
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Philips Magnavox 55P9271 55" Rear Projection Television Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
