TRAY WONT OPEN
SOURCE: samsung ht-q80 won't open tray
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
SOURCE: display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems
have a Dealer Lock or
Tray Lock Function that prevents
the disc tray from being opened.
There are four procedures
for turning off the Dealer
Lock function. Try one, then
the other, to see which works
on your system.
Unlocking Procedure 1
To turn off the Dealer
Lock function, follow these
steps:
Note: Repeating
the two steps above turns
the dealer lock on again.
Unlocking Procedure 2
steps
Note: Repeating
Unlocking Procedure 3
steps
Note: Repeating
the two steps above turns Dealer Lock on again.
Unlocking Procedure 4
steps
The Dealer Lock feature
is mainly used by retailers
to ensure that the display
discs are not removed. However,
parents of young children
may find this feature very useful
as well.
SOURCE: Samsung HT-C550 The DSP/EQ or the Dolby Pro Logic
I had the problem and after pressing the DVD Receiver\DVD button to no avail went back to setup and turned the ASC Setting to off. Apparently I had forgotten to turn it off after doing the Auto Calibration.
Hope this helps.
SOURCE: samsung ht c550, enciende, saluda,
when i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
SOURCE: samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/search.html?q=Samsung+HT-C550
