Question about Stanley Pneu Roof Stapler
Multiple nails are ejected
When I pull the trigger on my nailer, 2 or 3 nails are ejected into the wood.
  • jmorgia Feb 10, 2009
    Didn't help. by the way this isn't a shingle nailer. I am doing woodwork nailing. I am pushing down hard then pulling the trigger. I thought it may be oil. That didn't help either. I've wasted a couple hundred nails already.
  • 39 Answers
Its all about the pressure you solve this try pushing down then firing....i know its a pain and slows work a bit but it'll save you staples and from possibly firing THROUGH the shingle...pulling them up is enough of a pain anyway... also see if you can tighten the tip of the gun...that should make it less responsive, tighten the trigger as well...good luck
Posted on Feb 09, 2009
  • Ryan Peterman
    Ryan Peterman Feb 17, 2009
    wow thats a pain......well, my last idea is good are you at taking things apart....if you take it apart, clean everything, oil, new o rings (not that it would affect how many nails are ejected) and then put it all back togetherr (correctly) it should work more times than not..sorry my other ideas didnt help...good luck to you
Dewalt corless nailer lost power while puting nails in wood, he is working but does not have power to go all the way in the wood
Have you been keeping the gun properly lubricated? In the high dust atmosphere of the workplace it needs cleaned & lubed frequently.
Aug 01, 2012 | Dewalt DC618K - 18V, 16 Gauge, 20 Degree...
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
My DeWalt D51845 - when you use the sequential trigger it shoots maybe every 4th time you pull the trigger. If you replace the sequential with the bump trigger ever 3rd one shoots 2 nails.
Check this notice and post your question again if you nailer is not part of this recall. Good luck.
D51844 & D51845 Recall Notice Published 06/09/2005 08:49 AM ' Updated 09/29/2011 09:35 AM What is the recall on the D51844 and D51845 about? The contact trip on some of the nailers may not operate properly, which may permit a nail to be ejected with only trigger actuation.
Only nailers with the following date codes are affected:
200203, 200204, 200217, 200302, 200304, 200308, 200315, 200325, 200329, 200343, 200403, 200404, 200406, 200407, 200412, 200413, 200415, 200416, 200417
See the link listed below for illustrations & more information regarding the recall.
Oct 16, 2011 | Dewalt Round Head Framing Nailer D51845
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
Porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Aug 29, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Guns Safety problem
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Stanley Pneu Roof Stapler Logo
102 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
