Question about Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso water flows too quickly about 7 seconds
Rancilio Silvia Espresso Machine - water flows too quickly; about 7 seconds. Tried finer grind and packing harder, neither had any impact. Coffe ends up weak. Thanks.
  • steeves007 Feb 22, 2009
    Since I changed my boiler on my Rancilio Silva, the water seems to flow too quickly. I grind my coffee to the finest and tried tamping hard, less hard etc... any suggestions or I should simply have it serviced?
    Novelist:
  • 137 Answers
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Posted on Mar 30, 2009
How do i fix the Coffee flow from only dripping through?
if it has a filter ,replace. use vinegar through the water resevoir. fill it and turn it on.
May 26, 2014 | Rancilio Silvia Espresso Machine
No Hot Water
Sounds like your Rancilio needs a service, this problem could be caused by the boiler not working correctly, possibly a leak from the boiler or a valve malfunction causing a drop in pressure.
Mar 17, 2008 | Rancilio Silvia Espresso Machine
Our Silvia, almost 8 years old, is putting out shots too fast (10 to 15 seconds), even though we've been dialing down the grind on Rocky more fine, putting more coffee in, and tamping harder. We...
Try to redo what you have been doing, but set it to the extremes to see if everything is functioning. If you set the grind say to 4, it should come out very slow or maybe not at all.
Jul 11, 2011 | Rancilio Silvia Espresso Machine
On my rancilio silvia, 3 way valve not whooshing anymore. Water temperature seems low- around 180* at highest.
There are two thermostats, one for water, one for steam. Replace the one for water. You can get the themostat here
Rancilio Silvia Parts
Dec 06, 2010 | Rancilio Silvia Espresso Machine
I've tried grinds from a very fine to a coarser grind in my Rancilio Silvia, but the water is going through the portafilter/coffee too quickly. When I clean out the portafilter, there is too much dry...
Check the shower screen to make sure it is not damaged. Then try this get coffee ground from the store at #2, 3, 4 and 5 at least 1/4 pound each then use that to figure out what setting works best for your machine, also note the tamping pressure. Fill portafilter to rim then tamp to fill ring in basket.
Aug 24, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia not heating
Unplug machine and remove the top panel, check the thermostats on of them tripped reset and you should be back in business.
May 29, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Jan 26, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Manual for Rancilio Silvia V3 (two water supply tubes - why ? )
Hi
The second one is your relief valve return water line. It just sets in the tank. Doesn't go anywhere.
Dec 09, 2009 | Rancilio Coffee Makers & Espresso Machines
Rancilio Silvia Espresso Machine Logo
676 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
