Question about Adobe Computers & Internet
Download problem i cannot download adobe flash player ...it says you must run a 32 bit browser for a 64 bit operating system.i dont know what to do.....
    Problem Solver:
  • 12 Answers
Go to start then computer and windows look for exploer then open it and it lists two inernet exploers one regular and one 64 bit choose the regular one and it will work for you. if you need more help please respond.
Posted on Feb 09, 2009
How do i fix this
For games it is common to need Adobe Flash player installed: goto get.adobe.com/flashplayer/ be sure to clear the notch in the middle area with the advertisement download and let it install.
Some games might need Java: https://java.com/download be sure to know if you have 64-bit machine, then you will need to install both versions, 32 and 64 bit. Do Start - rightclick computer - properties, then somewhere in the middle it says 32 bit or 64 bit operating system. Search at the download site for 64 bit if needed.
Good luck !!
Jan 14, 2015 | Computers & Internet
Adobe flash player wont install
Try uninstalling the adobe flash player and re-installing latest Flash player again. It may have solved your problem.
You can download the latest flash players from here:
1. IE Browsers: http://filehippo.com/download_flashplayer_ie/
2. non_IE browsers: http://filehippo.com/download_flashplayer_firefox/
You should download the compatible (32 or 64 bit) versions as necessary.
If updating the flash players doesn't help you, you should re-install your browser or try another browser, because the problem may be caused by the browser also.
Hope this helps, Mrityunjay.
Jun 16, 2012 | Adobe Systems Adobe Flash Player
After i install and download the new adobe flash player I still can't get into any of my programs it is still telling me to download and install the flash player what can i do
LOL also make sure you download the CORRECT version not just the first link you are given !!!
There are a 32 bit version and a 64 bit version please take the time to get the correct one !
To check your version GOTo control panel, system,
Look around the middle of the screen and it should tell you which you need as indicated by
System type 64-bit Operating system
OR
System Type 32- bit Operating system
SAVE it to your computer DONT run it from the web as this can on occasion cause issues with installations.
Once saved DO REMOVE older versions before installing any other versions
and DO a shut down / restart of your computer before going on to install.
Your BROWSER type is also an important factor.
The OS (operating system) is another factor too !
There are different versions for different OS so make sure you get the version that matches your OS
Note that this is a COMPLETE answer not a half baked one as provided prev.
Oct 27, 2011 | Acer Computers & Internet
The first step in installing Adobe Flash is select operating system, then version, and I don't know what to specify for the Sylvania Netbook. Help?
Hi
if you go to
start
Highlight computer but dont open it
then right click it and go to properties
it should open a box showing you the system properties of your laptop
and about have way down it will tell you if you are running a 32-bit or a 64-bit system
then when you choose the adobe flash choose the one that is for your system 32 or 64
good luck
But if you are running a 64 bit system on windows 7 i dont think flash will work in 64-bit internet explorer
so you will have to go to start programes and internet explorer ( Not internet explorer 64 )
and use that one
good luck
Jan 30, 2011 | Sylvania G-Netbook
I play a game on facebook, and every time I go into the game, a screen says my plugin has crashed. What do I do to fix it?
Depend on your OS. If is Windows IE, some issues has found on this.
Try this :
our version of Windows is either a 32-bit operating system or a 64-bit operating system. A 64-bit operating system can run both 32-bit applications and 64-bit applications.Your browser, such as Internet Explorer, is either a 32-bit application or a 64-bit application. Flash Player works only with a browser that is a 32-bit application. On a 32-bit operating system, your browser is always a 32-bit application. However, on a 64-bit operating system, your browser is either a 32-bit application or a 64-bit application. Make sure you are using a 32-bit browser by following these instructions:
Windows with Internet Explorer
To make sure you are using a 32-bit version of Internet Explorer, follow these steps:
  1. In Internet Explorer's Help menu, select Help > About Internet Explorer. (In some versions of Internet Explorer, select the question mark in the upper right corner to select About Internet Explorer).
  2. If you do not see the words "64-bit Edition" next to the version number, you are running a 32-bit version of Internet Explorer. Continue to Determine the Flash Player version you installed, if any.
  3. If you do see the words "64-bit Edition", go to Flash Player on 64-bit operating systems (TechNote 6b3af6c9) to continue troubleshooting your Flash Player installation.
Windows with other browsers, such as Firefox, Google Chrome, or Opera
No official 64-bit version of these browsers is currently available on 64-bit Windows operating systems. Therefore, unless you are using a test version of a browser (not typical), your browser is a 32-bit application, and therefore, works with Flash Player. Continue to Determine the Flash Player version you installed, if any.
2. Determine the Flash Player version you installed, if any
Before you troubleshoot Flash Player installation, determine the version of Flash Player you have installed, if any. You can see if it is working and whether it is the latest version available for your operating system. Follow these steps:
  1. Go to http://www.adobe.com/software/flash/about. If you have already successfully installed Flash Player, the page displays the Adobe Flash Player version as shown in the following image:
    Note: The version number in this example might be different than the version you have installed.
    If you have not successfully installed Flash Player, you will not see the image.
  1. The same page http://www.adobe.com/software/flash/about has a table that shows the latest Flash Player version available for your operating system (for example, Windows or Macintosh) and your browser (for example, Internet Explorer or Firefox). If the version information shown in step 1 does not match the latest version shown in the table, upgrade to the latest version. To upgrade, continue to Uninstall previous versions of Flash Player.
Note:Internet Explorer uses a different Flash Player than other browsers such as Firefox or Google Chrome. Therefore, if you sometimes use Internet Explorer and sometimes use another browser, you might have installed a different version of Flash Player for Internet Explorer than for other browsers.
3. Uninstall previous versions of Flash Player
Before you install Flash Player for any Windows browser, uninstall all previous Flash Player versions and restart your computer. Follow these steps:
  1. Uninstall all previous Flash Player versions and restart your computer. For Flash Player uninstall instructions, see Uninstall Flash Player (TechNote tn_14157).
  2. Restart your computer after uninstalling.
  3. If you are using Internet Explorer, continue to Verify Internet Explorer security and ActiveX settings. Otherwise, continue to Download and install Adobe Flash Player.
4. Verify Internet Explorer security and ActiveX settings (skip for other browsers)
Make sure that Internet Explorer security default level is set to Medium. This level allows viewing ActiveX controls, such as Flash Player. To set browser security to Medium, perform the following steps:
  1. Open Internet Explorer.
  2. Choose Tools > Internet Options.
  3. Select the Security tab.
  4. Select Trusted Sites zone.
  5. Select the Default Level button. (If the Default Level button is dimmed, continue to the next step).
  6. Move the slider until the security level is Medium.
  7. Select Apply.
  8. Select the Internet zone.
  9. Repeat steps 5 - 7. When done, select OK.
Oct 04, 2010 | Adobe Computers & Internet
I have a windows 7 64 bit version. I cannot install adobe flash player. can i install a32 bit version to accomodate adobe flash player, if so how?
There isn't a 64-bit version of Flash Player (at least not yet).
While IE8 64-bit is your default browser, Flash content should open in IE8 32-bit.
Aug 27, 2010 | Computers & Internet
Says adobe flash player wont run on a 64 bit system, since having new laptop with windows 7, keeps saying adobe flash player cannot operate on a 64 bit system, so wont load zynga poker
Flash does work on Windows 7 64 bit, it just runs in 32 bit mode. Try using a 32bit version of the browser you use and installing flash there. Also make sure you are installing the latest version of the authentic adobe flash from http://get.adobe.com/flashplayer/
Apr 06, 2010 | Microsoft Computers & Internet
I need to change the settings on my computer from 32 bit to 64 bit so I can install Adobe Flash Player to play video clips in Real Player. What is the best & easiest way to do this?
Friend,
It is not the settings that change Windows from 32 to 64 bits. It is the Windows Operating System and the PC/laptop that too has to be 32 or 64 bits. You can install 32 bits Adobe Player from the net.
Jan 09, 2010 | Computers & Internet
Adobe Flash Player download problem
What Browser are you using, incidentally?
If you're trying to download the latest Flash Player, then maybe the link is detecting your browser... If you are using a 64-bit browser (I have no experience of these, I just think this might be worth a try) then maybe you should try installing Firefox and installing the Adobe Flash Player with that, to make sure you don't get 're-directed' to the 64-bit-message.
Try this link instead:
http://www.adobe.com/products/flashplayer/
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Dell Dimension 2400 PC Desktop
Adobe Flash Player problem
one of the ways the problem can be fixed is go to the adobe flash player website and read on some of the ways to fix the problem or u can uninstall it and reinstall it from the adobe flash player website
Computers & Internet Logo
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
