Question about GE Advantium 120 Convection/Microwave Oven
Clicking noise whem door is closed
I just installed a new Advantum 120 and it makes this wierd clicking noise when the door is closed and not running. When I open the door, the noise stops. Any ideas?
  • GE Master
  • 9,085 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Otherwise, see this video for help.
Posted on Feb 10, 2009
  • William Miller
    William Miller Feb 10, 2009
    Forgot to mention that since
    it's new (presumably less than one year old) it would be fully covered under warranty.
    I'd suggest contacting the manufacturer to get it fixed free.
    GE Customer Service is here.
    They can tell you who your nearest GE-authorized servicer is.
The fan on our microwave will not stop running
The circuit board is bad that controls it. try unplugging and waiting and plug it back up and see if that resets, if not I would take it in for repairs
Jan 13, 2015 | GE Advantium 120 Convection/Microwave Oven
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Kitchen aid microwave kbms1454rss clicking
Yes! from the information, you probably have one or two defective door switches. Parts need to be replaced for normal operation.
May 19, 2012 | Microwave Ovens
My microwave will not shut properly. The top latch will not completly close. The microwave still runs... but It will not heat food and it makes a clicking noise. Can this be fixed or should I purchase a...
Hi, quite often this is due to a bad door switch located inside behind the area where the door hooks go into the oven.
Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure.
In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide for $32.50, but it's usually a door switch.
It can be fixed......
Apr 28, 2011 | Whirlpool MH2155XP Microwave Oven
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    The microwave makes a low rumbling noise once the door is closed. The noise is similar to when the microwave is in use, just a little quieter. The noise occurs as soon as the door closes without pressing...
    There is a circuitry problem. Nothing should be on when the door closes and could be dangerous to diagnose for the untrained and inexperienced.
    Eric
    Nov 21, 2009 | Kenmore Microwave Ovens
    Kenmore Elite Advantum 120 Model # 363-63694302 INTERIOR Light not working
    I would suggest you look over this excellent tutorial.
    If this is not close enough to your oven to help, please reply back.
    Oct 05, 2008 | GE Advantium 120 Convection/Microwave Oven
    Ge sca1001hss01 otc advantum microwave
    First, order by number. Some illustrations are general. Second, you may find a board rebuilder who will fix yours or exchange it.
    I've done this and found that the correct product was sent and worked well.
    Dec 13, 2007 | GE JVM1650 1000 Watts Microwave Oven
    GE Microwave Model JES735
    Yes, the fan blade is hitting something inside.Usually by opening the microwave, you can slide or reposition the plastic fan blade on the shaft.Probably this happened in shipping to the store where you bought it.CAUTON:make sure the unit is unplugged before you attempt this.Other option is return for replacement.
    Nov 06, 2007 | GE JVM1630 Microwave Oven
    GE Advantium 120 Convection/Microwave Oven Logo
    358 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    D. E. Hev
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
