Question about Fisher Paykel EcoSmart GWL15
Fisher and Paykel Ecosmart continually gets off balance
Have had washer for going on two years and have this reaccuring problem from the beginning that the machine will become unbalanced no matter how balanced we make the load. Have found the right rear support rod stuck compressed after loads and had to manually unstick. Have verified with service tech on two occasions that system is level. Have instructed service tech to order new spring rods and problem went away for 6 month's and then returned. rotated rods and problem went away for a few weeks. Have not put another call due to it now being out of warranty and the techs in this area have very little knowledge of this unit and I am the one leading the troubleshooting when they get here.
  • Anonymous May 10, 2009
    are washer will continually go out of balance, and now we can't even get the machine reset to think that it is balanced.
  • Anonymous May 20, 2009
    We have had four service calls for this problem. The first call replaced the "tub suspension rods" (look like shock absorbers). It stiffened the tub movement but . . . Next call the tech was to have replaced the "feet" but the new feet sent did not fit the "washer wrapper." The tech was told by F&P to "redrill out the wrapper and retrofit the feet." The tech refused and ordered a "new wrap" to fit the new feet! The tech claimed a new wrap was made from a heavier gauge metal and would stop the vibrations causing the unbalanced movement of the machine. Now we are fighting F&P over replacing a three part motion and balancing sensor that seems to be the culprit . . . Supposedly, the machine is to stop after three attempts to correct the out of balance load. Our's does not stop. The machine actually "walks" and bangs up against the walls and sides of the dryer that is next to it. The tech "thinks" the motion and balancing sensor may be faulty but has yet to get F&P to approve its replacement. I'm about to video the problem and post it on YouTube! In the meantime, my wife is about ready to go "postal" on Lowes as she has spent 5 hours every Sunday for the past 4 Sundays doing laundry at the local laundramat at $50 per Sunday feeding washers and dryers . . . Did I mention our F&P Dryer - model DEGX2 just burned out its third heating element in less than a year? We're waiting on parts for that to be fixed as well!
  • 3 Answers
At the very top of the bowl is a fluid filled balance ring, I would say that all the fliud has leeked out into your wash over time and now you fluid level is low or dry , what i did is drilled two 8mm holes one on each side of the balance ring then pumped it full with 5 tubes of cheap and nasty grey plumbers silicon (only inject in one side to avoid air bubbles in bal ring keep pumping until the whole ring is full let half a tube or so squirt out the other side to get rid or air bubbles , let it dry for 48 hours cut the silcon flush with a sharp knife then all sweet as bro .
Posted on Jul 28, 2009
How to fix my fisher & paykel washer machine from shaking and knocking
Your 4 suspension rods will need replacing as they are loose & worn.
Or the bowl has lost its ballast water from the top & bottom balance rings of the bowl.
Jan 05, 2013 | Fisher Paykel WA42T26GW1 EcoSmart 25" Top...
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Our gwl11 fisher paykel washer will start to fill for about 5 seconds then stops
This is either your lid switch not working or your out of balance switch the latter being located under the large motor controller board under the controll panel.That should fix it.Kind Regards Stefan.
Jul 08, 2009 | Fisher Paykel EcoSmart GWL15
Fixed basket came loose...
if less than 2 yrs warranty and washer has 2 yr warranty (ck owners manual) call service ..if not remove plugs on front sides of top remove phillip screws lift top outer tub is supported by 4 swing arms one or more is probably loose or broke but can be replaced also have known then to just pop out of position with really bad off balance load
Aug 20, 2008 | Fisher Paykel EcoSmart GWL15
Leaking and off balance
Help, my paykel fisher ecosmart washer is 5 years old. It gets stuck in the rinse cycle with water overfilling. It does this even with one piece of clothing in it. It beeps letting us know that it is overfilling and we turn it off. Can not seen to reset. What can I do to fix this problem.
Apr 23, 2008 | Washing Machines
Fisher Paykel EcoSmart GWL15 Logo
1,541 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
